Go to Post Look, it's only August. You got approximately 6 months to enjoy your life until season starts. Enjoy it while it lasts... - Arefin Bari [more]
Unread 08-01-2013, 22:15
yarudl yarudl is offline
FRC #0578
yarudl is an unknown quantity at this point
Clutches
Are electro-mechanical clutches allowed? I've read the rules through and I've seen nothing that specifically prohibits them and I was wondering if they would be disallowed seeing as they involve an electro-magnet. If anyone has any insight into this I would be very grateful, thanks!!
Thanks,
Yarudl
Unread 08-01-2013, 22:45
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
Re: Clutches
I don't believe electro-magnets are allowed, because any bot on the pyramid at the end of a match has to be turned off before it is lowered. If it is turned off, the electro-magnet loses power and the bot will fall.
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 08-01-2013, 22:53
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
Re: Clutches
I don't think we are talking about the same thing here...
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 08-01-2013, 23:12
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Clutches
Because the relevant rule's phrasing is not concrete, this is open to interpretation, but I expect the answer to be no, as in the past, if something does not clearly fall into one of the listed categories, it is illegal.
R32 The only motors and actuators permitted on 2013 FRC ROBOTS include the following:
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 08-01-2013, 23:17
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Clutches
This is a good question for Q&A when it opens. The following might be relevant:
R32 allows for the use of
Electrical solenoid actuators, no greater than 1 in. stroke and rated electrical input power no greater than 10 watts (W) continuous duty at 12 volts (VDC)
in an unlimited quantity. if the GDC decides that electromagnetic clutches are allowed, they will likely need to fit this description.
Unread 08-01-2013, 23:46
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Clutches
It's also important to note that while some electromagnetic clutches contain solenoids, not all do. (Also, the definition of solenoid is itself open to some interpretation. I'd recommend also asking the GDC to define an electrical solenoid actuator, noting that the definition of a solenoid varies in different areas of engineering and scientific practice.)
Even though it's probably fair to say that a clutch is an actuator, electromagnets not used as actuators are not prohibited.
Unread 09-01-2013, 00:22
INTENSITY
Re: Clutches
Oh whoops! I saw "electromagnet" and just went straight to that. Thanks for the clarification.
Unread 25-01-2013, 20:17
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
Re: Clutches
could someone maybe shed some light on clutches that would be legal for use in FRC that you know of and where to buy said clutch?
Matthew Lantry
Team 4475 2014-present
-College Mentor 2014-????
Team 1676- 2011-2014
-Mechanical 2011-2014, Subteam leader 2013-2014
-Robot Operator 2014
George G. White FLL mentor 2011-2014
“Both optimists and pessimists contribute to our society. The optimist invents the airplane and the pessimist the parachute.”
Unread 25-01-2013, 23:45
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Re: Clutches
Dog gear clutches are legal. They are also relatively simple to use, and available on AM. Additionally, you can power them in a number of ways, including pancake cylinders, regular cylinders, servos, or window motors, all with properly designed (or purchased) linkages. The window motors are a bit abstract, but if you don't want pneumatics, they are more reliable than servos. Also, they look cool, and can shift multiple dogs at one time.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
