Go to Post Inspect every connection after every match. Use your eyes, ears and nose. - Al Skierkiewicz [more]
Unread 08-01-2013, 22:48
ktrobotcreator's Avatar
ktrobotcreator ktrobotcreator is offline
Programmer
FRC #1245 (Shazbots)
ktrobotcreator is an unknown quantity at this point
Re: January 8th Team Update
I am still confused about the zone thing. It seems that the rule is intended to mean you can't contact any more than one zone (so bars only and the whole floor), but that was never clarified. Timing on pyramid climbing has also not been specificed. Since there isn't a rule about it, we can assume you can start climbing whenever, but a clarification would still be nice. I am also confused about the starting positions. It seems like from the placement of the pyramid, if you are touching it, you always have to be between your auto line and the goals, but it says you can preload different numbers of frisbees depending on if you're behind it or not.
Thoughts?
