Go to Post The point is that while having the abiltity to find information in a variety of reference sources is a useful skill, it does not replace a good, complete, fundamental knowledge of your subject material. - dlavery [more]
  #61   Spotlight this post!
Unread 08-01-2013, 15:27
jeremy callahan's Avatar
jeremy callahan jeremy callahan is offline
FRC #5053
jeremy callahan will become famous soon enough
Re: Robot climbing times
Originally Posted by 1075guy View Post
I expect as always that the average team will struggle to score 7 3pters in the entire match.
The elite will be able to, but the best will 30pt hang in under 15 seconds also.
so do you think the hightest score will be like 98? im thinking 30pt hang, 7 discs 35pts, auton 18 for the "Elite Teams" extra 15 points?
  #62   Spotlight this post!
Unread 08-01-2013, 17:28
gabrielau23's Avatar
gabrielau23 gabrielau23 is offline
FRC #2537
gabrielau23 is just really nicegabrielau23 is just really nicegabrielau23 is just really nicegabrielau23 is just really nice
Originally Posted by Jared341 View Post
Miss Daisy, I have the utmost respect for your team and all that it is. You're consistently one of the best robots out there and play the game in ways 2537 could only dream of emulating. But if I asked Miss Daisy to find a way to climb the pyramid in 4 seconds, how realistic would it be? I don't see a way to do it unless you literally dedicate your robot to climbing. And you know just as well as I do that 30 (or maybe even 40 with dumping) is probably good enough for a regional but not good enough for the Newtons, Curies, Galileos, Archimedes and Einsteins. No disrespect, MD, but personally I think 4 seconds is simply ludicrous.
The higher I go up, the the faster the best times in my life (like build season) pass...so sad.
  #63   Spotlight this post!
Unread 08-01-2013, 21:27
EricDrost's Avatar
EricDrost EricDrost is offline
Eleven to MidKnight
FRC #1923 (The MidKnight Inventors)
EricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond repute
Wasn't a 1s minibot ludicrous during week one of Logomotion build season?
I wouldn't make such a bold statement, it's certainly in the realm of possibility. Some teams may have designs already that can do it.
MORT Team 11: 2008 - 2015
MKI Team 1923: 2015 - Present
  #64   Spotlight this post!
Unread 08-01-2013, 22:46
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I can envision a pretty darn fast mechanism for this, but you'd be dedicating your robot to a super-fast climb. Here's my thinking:
Common Sense Climbing: Most of us are thinking of a climber that has a moving grabber and a stationary grabber. Moving grabber latches on, pulls you up till you engage the stationary grabber. Then you extend the moving grabber, latch on again, and repeat till you get to the top. Doing all of that rapidly enough for a 4 second lift seems difficult. Plus is that this is (relatively) uncomplicated and light.
Superfast Climbing: You've dedicated your robot to climbing, so your climbing mechanism can be as heavy, bulky, and power hungry as necessary. So you make a climbing system with three different moving grabbers. Drive up to the pyramid, first grabber latches on and starts lifting. When it's done, your second grabber is perfectly positioned to latch on and start lifting, so it keeps pulling you up with very little pause. Ditto the third grabber. So you get nearly continuous lifting at the cost of building three moving grabbers instead of one. And powering them of course. My specific implementation of this would be a corner climber with three pairs of telescoping poles with spring loaded hooks to grab the rungs. You'd want some kind of shock on the idler wheel that's running up the pole, of course. And even then it'd be a pretty wild ride going up the corner that fast....
  #65   Spotlight this post!
Unread 08-01-2013, 22:52
pfreivald's Avatar
AKA: Patrick Freivald
From a rappelling exercise I did a long, long time ago, I know that you can rappel down a knotted rope without losing speed and without falling off when you hit the knot, using a rotating zip-climber that mechanically rotates itself around the knot without allowing a cantilever on the part of the climber.
Such a device is feasible for an FRC robot on the corner post -- clamp it on and power it, and then just drive up! (You'd go to half power over the knuckles -- compensated by momentum but detracted by gravity -- but full power elsewhere).
What it isn't is possible for 1551 to properly develop and test over a six-week period.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #66   Spotlight this post!
Unread 08-01-2013, 23:14
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Three hanging and dumping specialized bots on an alliance could easily get 120+ points. 3 hangs, 90 point total, 6 pyramid dumps, 30 more, auto dumps, up to 8 more, and then any dumps for 1 point goals from autonomous to hanging. Easily 120+pts, depends on if one bot can easily do all pyramid discs, while other 2 spam 1 point dumps.
  #67   Spotlight this post!
Unread 08-01-2013, 23:32
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Your math works, but I find this to be perhaps the most interesting use of the word "easily" I have ever seen. I wonder if you mightn't have confused it with "IRI".
Joking aside though, in most any situation where you could get 3 such robots on the same alliance [barring a very weird qual schedule], you are quite likely to be up against some beastly shooters + 10-20pt (maybe 30) hangers yourself. They'd give the hanging alliance a run for its money, particularly given the time they'd have unrestricted and the defense you can lay down against dumpers. In fact, with the strategy you just laid out, you'd be lucky to execute fully at all. My #1 priority would likely be keeping that colored-disk loaded bot away from their pyramid, and anyone running around loading and dumping before they hang will be in for some very tough driving. Their might be fouls involved (maybe even a technical), but even a 20pt technical is worth it if it prevents a 30-50pt hang. Nothing's ever as easy as it sounds.
  #68   Spotlight this post!
Unread 08-01-2013, 23:34
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I hate to spill the beans on this design, but since we almost certainly won't be using it, I might as well.
Minibot up the diagonal of the pyramid. This was the first thing that entered my head when I saw the challenge. Use a large pneumatic wheel to get over the crossbars, or an innovative wheel arrangement. Put two levels of idlers behind the pole, and be able to switch them over the crossbar quickly. You would clip onto the pole with your idlers, and just drive the pnumatic wheel up, and when you got to the crossbar, unclip your first idler, and after you've driven high enough to get over the bar, reclip it.
I think this is the only design that could get up in the under 10 range. Kevin, I don't think three arms is the way to go, or even possible for all but the best teams (who wouldn't want to go all out on it in favor of a shooter anyway).
If this such a good design, why aren't we going with it? Because it would be really hard to package with our shooter, and because climbing fast isn't all that important anyway.
-Plutarch
  #69   Spotlight this post!
Unread 08-01-2013, 23:50
I'm not proposing that as a sensible solution. Just as a method of ascending pretty much as quickly as possible.
Also, I'm having difficulty picturing your proposed solution. Specifically how you get the idler out of the way of the crossbar. If the idler is behind the crossbar, you'd have to move it outwards to disengage the pole, then sideways to clear the bar. Unless an idler is actually two idlers that come in from opposite sides and wrap around the pipe to keep you from sliding off sideways or something.
  #70   Spotlight this post!
Unread 08-01-2013, 23:53
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
This might be treading on thin ice. Depending on how you plan on "preventing" their hang, the judges might automatically award the 30 points anyway and give you a technical foul.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
  #71   Spotlight this post!
Unread 09-01-2013, 00:07
Siri's Avatar
Dare greatly
Interfering with Andy's strategy has almost nothing to do with directly preventing their hang. With three 30-point hangers running around the field trying to pick up colored disks and feed/dump, there would be plenty of opportunity for 'forced preoccupation' without putting a defender anywhere near their pyramid itself. (The only technical on the horizon would be a last-minute long pin.) If you're actually that good at 50pt climbs, you're going to have your hands full of people getting in your way any time you stray from the pyramid.
  #72   Spotlight this post!
Unread 09-01-2013, 01:02
Barry Bonzack's Avatar
Barry Bonzack Barry Bonzack is offline
Impossible to rain on my parade.
FRC #1902 (Exploding Bacon)
Barry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond reputeBarry Bonzack has a reputation beyond repute
Send a message via AIM to Barry Bonzack
I see a lot of sentences that start with "most teams will be able to..." but I think the sentences mean to read "most powerhouse teams will..." or "most teams that are playing in the finals will..." or "Most teams in the eliminations at the world championships will..."
based off of my memories of the 2004 and 2010 games, I believe this thread greatly underestimates the difficulty of climbing and overestimated what truly most teams, meaning more than 50% at any given regional, will be capable of. In 2010 I'd argue less than 50% of teams were able to climb 12" effectively, of the teams that could, at least 50% of them spent a significant amount of time just lining up to do so.
So I'm answering my opinion for the Average team, meaning the median team at any given regional, and the upper 10% powerhouse teams at any given regional. These numbers include time spent aligning, not just climbing.
10 points
The Average Team - 35 second
The Powerhouses - 8 seconds
20 points
The average team - 50% of teams will not climb to the 20 point range. Those that do will spend half the match doing so.
The powerhouses - 30 seconds
30 points -
The average team - Only the ones that build a bot dedicated to only climbing the tower, and spend the entire 2 minutes doing so.
the powerhouses - less than 50% of the powerhouses will *attempt it or **succeed. Average of those that do - ***40 seconds.
***before I get backlash, keep in mind what an average is. Yes some will do it much faster. Others will do it much slower, and many will spend a lot of time attempting it with no avail.
**Robots fall, things come loose and dangle... if a robot makes it to the top tier quickly, but its bumper fabric peels off and dangles 29" off the ground, it is still will only be worth 10 points. For my estimations, this is considered a 10 point climb.
*I believe most powerhouse teams will combine shooting and climbing for their strategy. I am expecting them to spend a long portion scoring many frisbees, then with 30-40 seconds remaining they will have a fast mechanism to get off the ground, and another to pull them above 30".
Chair of Florida FIRST Alumni
Orlando Regional Planning Committee
FIRST Tech Challenge Florida Leadership Team
Program Planner on the Orion Spacecraft at the Kennedy Space Center
Twitter: @FL_FIRST_Alumni
Events I'm Emceeing/Game Announcing:
1/10/2015 FTC Jacksonville League Championship
1/11/2015 FTC Central FL Tesla League Championship
1/17/2015 FTC South Florida League Championship
1/24/2015 FTC Tampa/St. Pete League Championship
2/7/2015 FLL Orlando Regional
2/14/2015 FTC State Championship
2/26-2/28/15 FRC South Florida Regional
3/8/2015 FLL State Championship
3/12-3/14/15 FRC Orlando Regional
4/22-4/25/15 FIRST World Championship Event - FTC Franklin Field
  #73   Spotlight this post!
Unread 09-01-2013, 01:06
DampRobot's Avatar
Physics Major
AKA: Roger Romani
While I haven't looked into the specific engineering yet, I was envisioning 4 pneumatic cylinders, two on each side, and actuating at a diagonal. When they would move back, they would both retract from the diagonal, and clear the crossbar.
-Plutarch
  #74   Spotlight this post!
Unread 09-01-2013, 01:10
AdamHeard's Avatar
Lead Mentor
Originally Posted by Barry Bonzack View Post
10 points
A single 2" bore (or dual 1.5" bore) pneumatic cylinders can do a 10 point hang (mounted vertically with a hook). This is also a buzzer beater.
This should be;
Almost Every Team - 3 seconds.
The powerhouses - 1 seconds.
Teams, you can 10 point hang; do it
  #75   Spotlight this post!
Unread 09-01-2013, 01:12
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
A single 2" bore (or dual 1.5" bore) pneumatic cylinders can do a 10 point hang. This is also a buzzer beater.
This should be;
I agree with you more on level 1 than Barry, I will think it will be a tad more than 3 seconds, but a good average.
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
