Go to Post The pie is as large as you make it. - boomergeek [more]
Unread 08-01-2013, 23:00
valkyrie2240 valkyrie2240 is offline
FRC #2240
valkyrie2240 is an unknown quantity at this point
Toughbox vs KOP Toughbox Mini
I've been looking at the differences between a normal 12.75:1 Toughbox and the KOP 10.71:1 Toughbox Mini for my team's chassis this year. I've been looking through the quick build chassis guide to see if using the Toughbox vs the Toughbox mini would change the assembly at all. I'm specifically looking at how to mount the toughboxes. Would anyone happen to know if we would have to make any changes to the KOP chassis to mount a normal Toughbox instead of the Toughbox mini?
Unread 08-01-2013, 23:02
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: Toughbox vs KOP Toughbox Mini
Any particular reason? We have quite a few Toughboxes. They weight a lot, and you can get a decent speed out of the Toughbox Mini.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 08-01-2013, 23:24
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Probably, since the big toughboxes were originally paired with the old KoP chassis (which is now illegal, I believe). But what do I know? I suspect you could, but do the math (you need to make sure that the output shaft of the toughbox doesn't interfere with the wheels, and that's pretty much it.)
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 08-01-2013, 23:31
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Your biggest concern is problem spacing with the output shaft... you'll need to make sure you get proper alignment and tension with the belts the KoP drive train has now! It may be a little trial and error, but I think those old Toughbox gearboxes had enough adjustment capability built in to make this possible.
2016: Lake Superior WFFA
Unread 08-01-2013, 23:40
Trish Fisher Trish Fisher is offline
FRC #2240 (Brute Force)
Trish Fisher is an unknown quantity at this point
The team is exploring ideas. Would using the toughbox make it harder for robots to push you around?
Does this mean that it is illegal to use a toughbox on this year's robot? I looked through the rules and I didn't see anything saying it was illegal, where would it be?
Unread 08-01-2013, 23:41
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
I don't think there has ever been a restriction on gear boxes (other than with window motors)
Unread 08-01-2013, 23:50
AKA: Nathan Hui
Increasing the gear ratio (making the drive slower) would make it harder for someone else to push you around, but you run the risk of popping breakers.
Again, what Christopher said, though I think the PG71 was also restricted last year.
Nathan Hui
FTC 4950, 6038
Unread 08-01-2013, 23:57
Shane 2429 Shane 2429 is offline
FRC #2429
Shane 2429 is infamous around these partsShane 2429 is infamous around these parts
Smile Re: Toughbox vs KOP Toughbox Mini
nope my team has been using standard tough boxes for a long time and i haven't seen anything about toughboxes being removed from available usage
also yes they do slow you down quite a bit but if you want to play defense its whatcha gonna need
also easiest way to mount tough boxes drill holes in the casing mount that t the chassis and and then use all-thread and or a piece of 1in by 1in square bar and basically bolt them together. you need to do this because the amount of torque outputed will bend the bolts holding your gearboxes in place over time
also go steel its much better to know you wont have to strip apart gearboxes in the middle of a comp
Unread 08-01-2013, 23:58
Don't you have that backwards?
Unread 09-01-2013, 04:36
AKA: Nathan Hui
Do I? Increasing the gear ratio means the motors turn more to get a single rotation of the output shaft, which slows down the drive, which allows more torque, which wins pushing matches while drawing more current. But I'm an EE, so what do I know?
Nathan Hui
FTC 4950, 6038
Unread 09-01-2013, 08:32
Mentor, LRI, MN RPC
It allows more torque at a higher motor speed... But your forgetting that the other robot is sitting there stalled. Stall = much, much higher current draw.
And seeing Ethers past contributions, like his recent tests on the speed controllers at Whirlpool's motor lab, I'm going to go with him on this one.
Unread 09-01-2013, 08:53
pfreivald's Avatar
AKA: Patrick Freivald
We used four 9:1 BB p80s on our Octocanum drive last year, then geared down a further 5:1 (net -- between the smaller traction wheels and a Gates belt with appropriately sized sprockets) when we got into pushing matches.
We got into lots and lots and lots and lots of pushing matches last year, and never once popped a breaker with a 45:1 reduction on four CIMs. Indeed, even with using pneumatics for the first time last year, and some extremely aggressive driving, we had better battery life than any other year thus far.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 09-01-2013, 09:01
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
There are no restrictions on gearboxes or aluminum.
From reading <R13> and <R19>, it appears to me that structures/gearboxes from previous years' robots are legal as long as
A. The structure/gearbox is unchanged from original purchase
OR
B. The structure/gearbox has been adapted specifically for this year's game
(which is to say if you have a piece of C-Channel from 2011, unchanged, it's legal. If you have a piece of C-Channel used on your 2011 robot and you cut it again for the 2013 robot, it's legal. If you custom-cut a piece of C-Channel for your 2011 robot and are using it unchanged from 2011, it's illegal.)
Although the motors allowed are restricted to the table in <R32>, there are no restrictions on gearboxes provided they meet <R16> and <R19>
Hi!
Unread 09-01-2013, 12:07
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
If your are stalled (0 RPM) the gear ratio has no effect on motor current. You will have a higher pushing force available with the higher ratio. (Newton will insist that if you are not accelerating the net force between the robots is 0). Other wise for a given output torque a higher (numerical) reduction will have the motor spinning faster at a lower torque therefore less current.
Unread 11-01-2013, 00:20
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
I think what Ether was pointing out is the part at the end about current. Increasing your gear ratio does increase motor revolutions relative to the output shaft, and increases torque. But this lowers overall current draw for the equivalent torque output, which would reduce breaker trips.
