Go to Post I hope FIRST hurries up and releases the regional schedule soon. I have a vacation schedule to plan. - Koko Ed [more]
Unread 08-01-2013, 23:04
clandry94 clandry94 is offline
AKA: Conor
FRC #3735 (KleinBOTS)
clandry94 is an unknown quantity at this point
Smile Best motor/gearing option to drive a shooter?
Using a linear shooting system what would be the best way to drive those motors? By looking at Andymark I noticed the Double Doozy assembly http://www.andymark.com/product-p/am-0629.htm for the AM 9015 motors and then the http://www.andymark.com/product-p/am-0449.htm gearbox. From what i've roughly calculated that would give around a 2,000 rpm output. Would this be enough to launch a frisbee a reasonable distance?
Unread 08-01-2013, 23:25
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: Best motor/gearing option to drive a shooter?
You won't know for sure until you slap the thing together and toss a frisbee. Also, a "reasonable distance" might be anything from 2 feet to 40 feet. It depends on what "reasonable" is to you. Check your game strategy.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 08-01-2013, 23:33
Dominator1619's Avatar
Dominator1619 Dominator1619 is offline
FRC #0313 (Bionic Zebras)
Dominator1619 is an unknown quantity at this point
That truly depends on how far and what goals you are aiming for. Just to give you an idea, watch the robot in 3 days video about their linear shooter. They are using a CIM geared up to roughly 8,000 RPM (if I'm remembering correctly they are gear up about 1.5:1 and a CIM standard is around 5,200 RPM). You also have to consider the pressure you are applying to a disc and how much that affects the speed of your shooter. I would suggest looking through all the legal motors that you don't plan on using for other things and see what you can find. A good place to start can be the BaneBots motors. Many of those motors have a very high RPM output and have many options to how you can apply them for your needs.
So where is this cake I was promised?
Unread 08-01-2013, 23:40
Is consistency important to you? If you run it at free speed, there's no headroom for speed control.
What's your wheel diameter?
Theoretical frisbee exit speed in mph (no slipping) is given by
pi*d*s/2112
"d" is wheel diameter in inches.
"s" is wheel speed in rpm
If there is slippage between the wheel and frisbee, the exit speed will be lower.
If there is slippage between the chute and frisbee, the exit speed will be higher.
Unread 10-01-2013, 01:36
AKA: Conor
pi*d*s/2112
Is this exit speed in feet per second?
Unread 10-01-2013, 01:40
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
I believe he has it listed in miles per hour. Just do some unit conversions.
Unread 10-01-2013, 09:00
AKA: Conor
That would give an 8,000rpm, 8inch wheel (exactly like robot in 3 days) and exit speed of 95 MPH. Seems a tad fast for a frisbee exit speed.
Unread 10-01-2013, 09:13
Andrew Lawrence
Posts: n/a
Just to throw it out there, the MiniCim actually spins faster than the CIM motor (free speed 6200 rpm, compared to the CIM motor's 5310).
Unread 10-01-2013, 10:10
question:
answer:
Theoretical frisbee exit speed in mph (no slipping) is given by...
Not saying you're wrong, but where did you get the 8000 rpm number from ?
Unread 10-01-2013, 10:16
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
5200 rpm CIM geared at 1.5:1 => 7800 rpm. He rounded that up.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 10-01-2013, 10:18
Who said they are running it at full voltage ?
Unread 10-01-2013, 10:46
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Before we can answer the question of the best motor/gearing option, we need to determine the ideal exit speed.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 10-01-2013, 11:00
Does anyone have any data (actual measurements) for the following?
1) what effect do different shooter wheel speeds have on frisbee flight path (e.g. height at the target distance) ?
2) how much does your shooter wheel slow down when a frisbee passes through it ?
Unread 10-01-2013, 12:30
Aren Siekmeier's Avatar
on walkabout
Your best bet to determine any of this is to put together something with a launch speed in the desired ballpark and test the desired shot. Then you don't need any math beyond knowing how things scale. We have run all of our tests off of a UPS (uninterruptible power supply) so that we can adjust the voltage to get the desired launch speed. Knowing this speed makes it much easier to design the final mechanism, and we haven't needed any frisbee flight models, only repeated testing.
Of course, we are not simulating any shooter spin down with a UPS, but as already mentioned, leaving headroom for speed control should take care of this.
