Go to Post Antimatter.. It will help us in the never ending quest to build the bot under the weight limit. - Elgin Clock [more]
Unread 09-01-2013, 00:09
Dumper FTW 435's Avatar
Dumper FTW 435 Dumper FTW 435 is offline
AKA: Ryan
FRC #0435 (Robodogs)
Dumper FTW 435 is an unknown quantity at this point
Mecanum vs Treads
One of the biggest issues with my team right now is the debate between mecanum wheels vs treads. I was wondering what you all thought.
The proponents for treads believe it is essential for preventing other teams from pushing us when we're trying to shoot, and allow us to push defensive robots trying to get in our way. We've had a lot of good luck with treads in the past, and it's proven to be very effective.
The proponents for mecanums believe that we need strafing and other fine control inorder to pick up disks (since our disk pick up mechanism will likely be finicky and difficult to aim. We have also used mecanums in the past to good effect.
I was originally supportive of treads, but as I realized how hard it would be to pick up disks, i became undecided.
Our strategy for this year is likely to be offensive, where we try to consistently shoot 2 or 3 pointers, but we also like having a defensive option in case the shooter doesn't work, or if we need to shove defenders out of our way.
What do you guys think?
Unread 09-01-2013, 00:14
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Mecanum vs Treads
Consider a simple 6-wheel dropped center tank drive. It allows for being fast and/ or pushy (depending on gears) and is very maneuverable. Treads are slow and have high friction, while mecanum wheels have low friction and efficiency.
(My $0.02)
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 09-01-2013, 00:19
Shane 2429 Shane 2429 is offline
FRC #2429
Shane 2429 is infamous around these partsShane 2429 is infamous around these parts
Lightbulb Re: Mecanum vs Treads
use treads or a multiple wheel drive system this is not the year for mechanum yes its fast and maneuverable but has absolutely no torque a robot could push you using CIMple boxes for gear boxes
if your gonna shoot and stay still for long amounts of time use treads also probably a good idea to build your shooter with turret so your driver can focus on the keeping the defender from moving your robot and not aiming the robot
Unread 09-01-2013, 00:20
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
I suggest you count the number of Einstein robots which used treads and mecanums.
Don't count on mecanums to compensate for a poor harvester design, and don't count on treads to make you immune to defense. Both will disappoint. In this game, where the field is wide open, the maneuverability of mecanums is not as beneficial as it has been in some years. You'll probably need to make some full-field sprints, and both mecanums and treads sacrifice power that you'll desparately want.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 09-01-2013, 00:25
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
If I remember correctly that number is still 0 for mecanums.
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 09-01-2013, 00:51
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Also important, mecanums need all four wheels solidly on the ground to function correctly. See that drawing of that bump around the entire pyramid? That bump means mecanums are going to hate driving near the pyramids. Any precision driving you try to do near the pyramids is guaranteed to take twice as long on mecanums as it would on a 6 wheel drive.
Unread 09-01-2013, 05:29
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
I don't understand this at all, how does the bump make mecanums not work? We used them last year and got double or single bridge balances very easily
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 09-01-2013, 07:13
Chris C. 2410 Chris C. 2410 is offline
FRC #2410
Chris C. 2410 is an unknown quantity at this point
That may have depended on which mecanums you used.
What I would say is from a repair standpoint, mecanums will be quite a bit easier. I am a huge fan of treads, but replacing them is tricky enough that I wouldn't consider using them unless you had a really good reason. There are ways to do it quickly, for example slotting the frame, but you have to have confidence in your ability to fabricate it properly. Mecanums are nice because if you have a problem with one, it is a self contained module. You can pull one off and pop a replacement in much faster than with a tread system.
My question is if you were debating treads, why not reasses the merit of the standard 6WD system? It seems like you are debating highly mobile vs. heavy and slow.
Unread 09-01-2013, 08:00
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
If I remember correctly, 100% of 9-sided teams won Einstein. So you should do that.
Just because something has never been done, doesn't mean it's impossible. See: everything ever.
Hi!
Unread 09-01-2013, 08:03
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
It has to deal with weight. Meccanum drive relies on an even weight distribution on each wheel for accurate strafing and turning. if you don't have that, the robot will strafe in a slightly offset angle. Introduce a different height for 2 wheels, and suddenly your back wheels have more weight than your front. It only affects strafing though, if I remember correctly.
Also, some non selling points for meccanum:
Actually learning to take advantage of strafe is harder than it looks. Have you ever played Halo and strafed at all? I don't think i've strafed at all when fighting in Halo 4. I'll bet when you play halo, the majority of the time you move the player's orientation and have him walking in that direction instead of strafing. The only times I strafe is to snipe and to avoid shots, both of which probably won't be done in this year's FRC game.
Meccanum also uses the vectors of motion on the wheel to produce strafing motion. Unless your PID is tuned to godly precision, you're always going to have some cancelled force, reducing your strafing accuracy and your power.
Also, the coefficient of friction on those wheels is low. Unless your control system has taken account for your driver
s tendencies, its going to be a lot easier to slip and waste even more drivetrain power.
See if these outweigh any advantage you think you may be getting. I don't know, they might for you.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 09-01-2013, 09:06
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
I would questions two things in your thought process.
First do you really think picking up frisbees will be worth compromising your drivetrain decision? It may be an okay strategy for qualifications, but if you're picking up non-trivial amounts of discs in eliminations it means either 1) your alliance partners are missing lots of shots (very bad, you probably can't make up for them) or 2) your opponents are missing lots of shots (in which case they aren't a very serious opponent anyway) or 3) it's the last 30s of the match, human players are throwing discs in, and you can reliably score more points by hanging than a last-minute grab and shoot of a few discs.
Second, if your robot is touching your pyramid you're more or less protected from being interfered with while shooting. Additionally, your robot can be aligned against the pyramid to help your aim.
In my mind you don't have a really strong argument for either mecanum wheels or treads. To pick between the two I would say treads would make your more effective at breaking past defensive robots, provided they could be fast enough to effectively traverse the field end-to-end (10-12ft/s I'd guess). However, I think a 6WD drivetrain would be at least as effective as treads.
Unread 09-01-2013, 09:12
Take a look at the force vector diagram for the mecanum drivetrain. The wheels always apply force at 45 degrees from the direction of the wheel rim. The only reason you can drive straight with them is because opposite pairs of wheels push against each other, cancelling the sideways force and resulting in straight motion. When you take one of those wheels out of the equation or start shifting weights unevenly between wheels, things start getting wonky pretty quickly. The fact that the rollers aren't perfectly frictionless means driving straight isn't affected quite as much as strafing, but the effect is still there.
Unread 09-01-2013, 09:27
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
I'll be the voice from the other side since so many seem to immediately dismiss mecanum wheels.
I don't think this is true, at all. Guaranteed? Would love to know why it's guaranteed.
One set of wheels, either front or back, should have some kind of suspension or adjust-ability built in to compensate for the variations in the floor around the pyramid in order to maintain driving as usual. However, I'd argue that even without it you would probably still be able to strafe with two front wheels on the raised part & two wheels off the raised part. Even weight distribution would be important but it would still work, perhaps with a little driver compensation involved.
If your team is considering mecanum wheels, it needs to be because your team thinks it gives you a competitive advantage and that it plays a part in your overall design strategy. Maybe your frisbee intake from the slot is on the side of your robot, so you can strafe into the wall and pick up frisbees but have your shooter on the front or back of your robot. That's just one example. A mecanum drive also means you're choosing to play pure offense, which isn't a bad thing. Give your driver enough time to learn how to really use the drive effectively.
My opinion is that you have a wide open field this year, fewer obstacles than last year to navigate around and a quick mecanum drive could be very effective if the driver is well-versed in using it.
I don't get this notion of dismissing mecanum drives just because they haven't 'been to Einstein.' The majority of teams in FIRST haven't been to Einstein, that doesn't mean the choices they made or will make for their robots are wrong.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 09-01-2013, 09:37
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
If somebody forced me to choose between mecanum and treads, I'd choose mecanum. Not because I think it would be good this year (I don't), but because treads are a bunch of extra work while mecanum can be quickly bought and assembled without any fancy design and fabrication.
It seems like an obvious 6WD kind of year to me. The climbing and frisbee pickup is so complicated and difficult that I wouldn't want to spend any precious time designing a drive system, unless it somehow tied into the climbing ability.
Strafing doesn't seem like much of a benefit this year. Like last year, you can pivot to aim your shot. I liked it in 2011 when strafing made it easier to score tubes.
Unread 09-01-2013, 09:47
J.Warsoff's Avatar
J.Warsoff J.Warsoff is offline
BECAUSE SCIENCE
AKA: Jared Warsoff
FRC #1676 (The Pascack PI-oneers)
J.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond repute
Mecanum wheels will allow you high maneuverability options (e.g. strafing), which would indeed come in handy this year, since there are no humps or anything on the field. This can help get you around defending robots, or be a good defending robot yourself.
On the other hand, treads will give you much more traction, therefore giving you more pushing power, as you did find.
All of this is going to depend on what kind of robot you want to build. Defensive bot? Offensive bot? Maybe a little bit of both? Other things like how you shoot, acquire discs, and other factors will also be variables in this.
"I reject your reality, and substitute my own!" -Adam Savage
Check me out on Twitter or Facebook
Acoustical Engineering & Music major at the University of Hartford / Hartt School of Music Class of 2017
