Re: unlimited storage tanks and cylinders??
Consider that the tanks were supposed to be filled by the competition battery each match, and that tanks do not fill instantaneously (some teams took 7+ minutes to fill). This may not seem like a big deal, but it's definitely something to panic about when you've just let the air out and you have 5 minutes to be on the field.
How many uses can you get out of a piston? Is there a calculation one can use to figure out how much air pressure/ volume the robot would need to actuate the piston X number of times?
This caused a bit of an uproar here on CD, which makes me believe regionals will be looking more closely at teams with such compressors in their pits this year to make sure they are following the rules. |
