Go to Post ... so I have to ask: ... Are you nuts? - I hope you are - as crazy as Dean :^) - KenWittlief [more]
Unread 09-01-2013, 10:46
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Safely letting the robot down
Do you think it would be a good idea to have a small electric winch attached to the tower to safely let the robots down? The winches can be purchased for as little as $70.00 at Wallmart. It seems to me 150 lbs robot high in the air is a recipe for disaster especially during prototype.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 09-01-2013, 10:48
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: Safely letting the robot down
For competition, you're required to use the belay system if any part of your robot is in zone 3 (i.e. higher than the second crossbar). For practice/prototyping, having some kind of belay system of your own is probably a good decision, even when climbing if you can do so safely, to prevent catastrophic failures.
Unread 09-01-2013, 10:49
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
That could be a great idea for your build space/testing. On the field, however, I don't think it will be allowed. They belaying system is in place to help with that.
Also, if you're planning on climbing to level 3, it would be a good idea to incorporate into your lifting mechanism an assist for lower the robot. For example, if climbing with pneumatics, managing the airflow when you empty the tanks may give you a slower release and lowering of the robot.
2016: Lake Superior WFFA
Unread 09-01-2013, 10:54
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
I could see a little time being used to safely bring down 3 robots. I was thinking it could be used to lower up to 3 robots at a time to save time.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 09-01-2013, 10:59
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
FIRST would have to approve such a thing to be used at the events.
