Go to Post make your robot so it's not a problem and it won't be a problem - pfreivald [more]
Unread 09-01-2013, 09:32
Stonemotmot Stonemotmot is offline
FRC #0486
Stonemotmot is an unknown quantity at this point
Error on using network tables from smartdashboard.
Hello, I am trying to send some simple double values from the smart dashboard to the robot the problem is the data does not appear to be recieved and I get a flood of messages from the network tables such as the ones below.
connection state: GOT_CONNECTION_FROM_CLIENT
edu.wpi.first.wpilibj.networktables2.server.Server ConnectionAdapter@14f entered
connection state: SERVER_ERROR: class
edu.wpi.first.wpilibj.networktables2.connection.Ba dMessageException: Unknown Network Table Message Type: 12
Close: edu.wpi.first.wpilibj.networktables2.server.Server ConnectionAdapter@14f
The Code I use is as follows
SmartDashboard Code
public static NetworkTable table;
public int network=0;
public WPIImage processImage (WPIColorImage image)
    if (network==0)
     NetworkTable.setIPaddress("10.4.86.2");
     table = NetworkTable.getTable("camera");
     network=1
      table.putDouble("AREA", 2);
Robot Code
public static NetworkTable cameraTable = NetworkTable.getTable("camera");
function()
System.out.println(cameraTable.getNumber("AREA",-1);
The above code displays the previous error and -1(the default output)
Any help is much appreciated.
Unread 09-01-2013, 09:36
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: Error on using network tables from smartdashboard.
I believe you have to actually create a table called camera before you can try to get anything from it. I don't have access to the javadocs for the NetworkTable right now.
Unread 09-01-2013, 09:40
FRC #0486
The description in the java doc for getTable() is
Gets the table with the specified key. If a table does not excist, a new table will be created. This will automatically initialize network tables if it has not been already.
to mean that means that no seprate creation is nessasary, but if im wrong how do i create one?
Unread 09-01-2013, 09:54
MagiChau's Avatar
AKA: Michael Chau
The actual error appears to be "Unknown Network Table Message Type: 12"
I actually was on the wrong track then. It is an issue with communicating using table "camera" probably when you are trying to retrieve a number or it could be when you put the number in.
Perhaps someone else more experienced can help you, I am trying to guess the most likely errors.
Unread 09-01-2013, 10:15
FRC #0486
I have been trying to find a solution using what you said but I still cant figure out what is wrong.
Unread 09-01-2013, 10:48
MagiChau's Avatar
AKA: Michael Chau
You put in a number under the key of "area" but you try to retrieve with the key "RED_AREA" try changing "RED_AREA" to "area" when you use getNumber()
Unread 09-01-2013, 11:03
FRC #0486
Oh sorry that was a miss type in the post. In my actual code they are the same. Sorry for the confusion.
Unread 09-01-2013, 11:55
If I had to guess, I'd say your smartdashboard code is using Network Tables Version 1, while the cRIO is running a Network Tables 2 server.
Unread 09-01-2013, 12:30
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Is there any documentation specifically for using NetworkTables2 yet? I noticed the documents for NT on screensteps are still empty.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 09-01-2013, 16:02
mitchellweb1 mitchellweb1 is offline
AKA: Mitchell W
FRC #0190
mitchellweb1 is an unknown quantity at this point
Yes I believe this is the error which you will get if the smart dashboard is running the old version of Network Tables.
You can go here to get the latest version of SmartDashboard which uses NetworkTables2
http://wpilib.screenstepslive.com/s/...sion-installer
Unread 09-01-2013, 19:26
FRC #0486
Talking Re: Error on using network tables from smartdashboard.
Thanks for everyones' input. I have re-installed the dashboard and no longer get the error. However the data is still not sent from the dashboard to the network tables. I have used the NetworkTable Viewer to determine that the Robot communicates with the Network Tables just fine, but the dashboard seems unable to. I used the code below on the robot to put and retrieve values and this works just fine.
NetworkTable.getTable("MyTable").putDouble("AREA", 5);
System.out.println(NetworkTable.getTable("MyTable").getNumber("AREA",-1));
I have had no success repeating this on the dashboard however. If someone could post some SmartDashboard network table code from this season using the new crio image and new SmartDashboard I would very much appreciate it.
Unread 09-01-2013, 19:48
AKA: Mitchell W
FRC #0190
You have to put values using the SmartDashboard class
For example http://wpilib.screenstepslive.com/s/...-robot-program
SmartDashboard only looks at a single table in networktables so that you can use other tables to send data to other programs but not have it show up on the SmartDashboard
You can also find more info on the SmartDashboard here http://wpilib.screenstepslive.com/s/3120/m/7932
Unread 09-01-2013, 20:00
FRC #0486
I might be wrong, but I thought the SmartDashboard class could only be used on the robot not in the dashboard itself(don't have it in front of me at the moment)
I am trying to send data from the dashboard to the robot not the other way around. Should I use a table called "SmartDashboard" would that work?
Unread 10-01-2013, 14:46
AKA: Mitchell W
FRC #0190
Sorry I misunderstood your question. You should be able to do Robot.getTable() to get the SmartDashboard table from the plugin.
Unread 10-01-2013, 15:23
FRC #0486
Thank you! that did it.
