Go to Post Silly, Silly, don't you realize there are no borders in FIRST:) - HW [more]
Unread 09-01-2013, 08:37
sprocketman92's Avatar
sprocketman92 sprocketman92 is offline
AKA: Brent Butler
FRC #3947 (The Last Crusaders)
sprocketman92 is on a distinguished road
[FTC]: Set Screws Suck!!!
We are having serious problems with wheels and gears coming loose or totally falling off because the set screws keep coming loose. I was wondering what other teams do to avoid this? Please and Thank You
Don't tell me it won't work....... MAKE IT WORK!
Unread 09-01-2013, 12:05
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: [FTC]: Set Screws Suck!!!
Make sure the set screws are engaged to the flat of the shafts, and torque the set screws in with the allen key. If that still doesn't work, replace the screw itself (it may be worn, you'll notice it if you look at the tip of the set screw, which would be silver instead of black.)
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 09-01-2013, 12:32
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
File down the tip of the set screw, or replace the set screw with a machine bolt. This spreads the stresses of the set screw out more, making the set screw less likely to slip in the first place.
GitHub
Unread 09-01-2013, 12:50
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
We put a dab of red Loctite on some of ours. It helps a bit and you can still get them out (with additional effort) if you want to.
Unread 09-01-2013, 14:08
AKA: Nathan Hui
Actually, I would not replace the set screw with a machine bolt, primarily because the machine bolt doesn't have a finished end, unlike a set screw, which (most probably) has a machined cup point, which is designed to really grab a shaft. In certain applications, it is advisable to file down the tip of the set screw, but I do not believe that this case is one of them, unless of course you are using a flat tip set screw.
The one time I used a machine bolt (Socket Head Cap Screw, 10-32, 2", Black Oxide Steel) as a set screw, I completely destroyed the tip (the metal in the bolt was too soft).
Nathan Hui
FTC 4950, 6038
Unread 09-01-2013, 14:31
JesseK's Avatar
FRC #1885 (ILITE)
I guess we have different anecdotes then. We've never had a problem with machine bolts as set screws on a flattened face in either FRC or FTC.
We used machine bolts on the inner rail shaft collars of FTC 354's champs-winning robot last year. They worked fine, even with the super high-traction wheels.
GitHub
Unread 09-01-2013, 16:09
AKA: Nathan Hui
hmm. Well, I was placing well over 300 in-lb torque when the machine bolt failed, so that is probably one of the mitigating factors.
Nathan Hui
FTC 4950, 6038
Unread 10-01-2013, 08:04
AKA: Brent Butler
Thank you all for your help we have plenty of options to try because of all of you!
Unread 11-01-2013, 12:46
coollog's Avatar
coollog coollog is offline
Q
AKA: Qingyang Chen
FTC #5485 (PRO)
coollog is an unknown quantity at this point
Also, try to not use set screws whenever possible and keep axles themselves stationary, but the components (wheels and gears) free to rotate on the axle. So, whenever possible, remove axle hubs and add shaft collars.
Qingyang Chen
FTC Team 5485 - PRO, Horseheads, NY
Sponsored by Corning Inc.
Join our fan page: <http://www.facebook.com/ftcpro>
Unread 14-01-2013, 13:07
sandiegodan's Avatar
sandiegodan sandiegodan is offline
FTC Mentor, FRC Inspector
AKA: Dan Glenn
FTC #10092 (Green.Griffins;)
sandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to all
+1 on filing the set screws flat on the tips. Things were much more stable once we did this.
If you are filing manually, put a wrench into the setscrew and hold the two together then rub along a stationary file or flat sandpaper. It's easier to keep the file perpendicular to the set screw. I like using a bare grip as it is easy to judge if you are being too aggressive either with pressure or speed or both by the heat you are generating. It should never be uncomfortable to hold.
Dan Glenn
2015-16 FRC Chairman, San Diego Regional Planning Committee
2016 FRC Inspector, Orange County (LRI), Los Angeles, Carson Division
2015 FRC Inspector, Inland Empire (LRI), Central Valley, Los Angeles, Galileo Division
2015 FTC Mentor 10092 Green.Griffins; R&D Robotics Education
2014 FRC Inspector, Inland Empire, San Diego(LRI), Archimedes Division
2012-15 FTC Mentor Team 6565 Stuffed Dragons & 8489 Green Griffins Boys and Girls Club
2013 FRC Inspector, Central Valley, San Diego(LRI), Los Angeles, Inland Empire, Galileo Division
2012 FRC Inspector, San Diego, Los Angeles, Central Valley, Newton Division
2009-12 FRC Mentor Team 1622 Spyder Poway HS
2007-08 FRC Mentor Team 2658 Pedestrian Rancho Bernardo HS
