Go to Post I dont think it matters too much what you do, as long as you do something that lets you apply what you're learning in class. - MrForbes [more]
Unread 09-01-2013, 12:16
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Jump Start Build - Control System Startup Suggestions
For everyone that doesn't know, my name is Ryan Nazaretian. I've been the lead programming mentor for Team Fusion 364 for the past 2 years. I've been involved with Team Fusion since 2003; all the way from their summer camp program in 7th grade, to being a mentor now. I'm going to Mississippi State University for Computer Engineering, and I'm a senior this year.
Team Combustion 1912 holds the annual Jump Start Build at Northshore High School on the first Saturday after Kickoff with the help of Team Chaos 1421, and Team Fusion 364.
For the past few years I have been going to help with the control system startup. This year, I want some feedback of some mentors, students, anyone involved with FIRST Robotics.
At competition, what are some things that you see that team poorly execute? Should they have put in a potentiometer to help with control? Are they failing inspections (control system specific)?
If you are attending Jump Start Building, what would you like me to cover? Do you want to use the compressor but don't know how? Would you like to control the position of an arm using some form of closed loop control? Otherwise, I'll go straight to the point:
  1. Software Updates
  2. Software Installation <- This first because it takes ssssssoooooo lllooonnnggg... We'll skip ahead while everyone installs the software.
  3. System Integration - Putting it all together (hardware)
  4. Dlink Router Setup (Firmware Update, IP Configuration)
  5. Formatting your Compact RIO
  6. Intro to Robot Framework - Making your first cRIO Program
  7. Running your first cRIO program
  8. 'Burning' your first cRIO Program
But yea, let me hear it! I'm excited!
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 09-01-2013, 13:48
Re: Jump Start Build - Control System Startup Suggestions
What do I often see poorly executed? Wiring.
There's really only one way to connect power to everything and have it work properly. Apparently the power distribution diagram isn't obvious enough for some teams to get it right.
Unread 09-01-2013, 14:14
RyanN's Avatar
RyanN
Good one!
I take good wiring for granted with our team. Neatness, labeling, correct size, and make sure it goes to the correct place (Dlink to converter to boosted 12V, cRIO (8-slot & 4-slot) to the 24V output, camera to 5V output, 20A breakers for all control system components.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 09-01-2013, 14:22
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Is this the same as the RQBS?
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 09-01-2013, 15:32
3132MentorMike 3132MentorMike is offline
Set the bar higher than you imagine
AKA: Mike Heimlich
FRC #3132 (Thunder Down Under)
3132MentorMike is a jewel in the rough3132MentorMike is a jewel in the rough3132MentorMike is a jewel in the rough
Ryan - to go one step further, you should teach a proper technique on preparing the wires (Anderson's, spade connectors, etc.) as well as proper strain relief. A great mentor in NH on 2342, "Mr. T", teaches a technique (where applicable, depending on the connector) of crimp, solder, and shrink tube that I've never seen fail on robot in 5 years.
Also caution teams on long runs of unshielded PWM cables. A discussion on EMI/EMC/signal integrity is probably going to go over their heads, but "too long" needs to be something in their vocabulary.
Unread 09-01-2013, 15:47
RyanN's Avatar
RyanN
I believe it's very much the same. The goal is to have a running kitbot at the end of the day.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
