Go to Post There's the problem!! The #1 reason to blame the programmers: They always forget to grease their code. :rolleyes: - Jack Jones [more]
Unread 09-01-2013, 11:50
Cadorean Cadorean is offline
AKA: Andrew
FRC #4621 (Yotta Robota)
Cadorean is an unknown quantity at this point
LiveWindow Won't Import
We used RobotBuilder to start making our code since we only have a couple experienced programmers, but when we open the code in NetBeans we get the error message "package edu.wpi.first.wpilibj.livewindow does not exist"
The issue is only showing up in the RobotMap class. I was wondering how much of a problem this is, and how we would go about fixing it.
Unread 09-01-2013, 12:28
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: LiveWindow Won't Import
Have you updated your netbeans plugins to the 2013 version? Check to make sure your update URL is http://first.wpi.edu/FRC/java/netbea...se/updates.xml
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 09-01-2013, 13:01
AKA: Andrew
That fixed the problem. Thank you!
Unread 09-01-2013, 13:07
If you run the version of robot builder that comes with the java plugins, you'll make sure the Robot Builder version is always compatible. http://wpilib.screenstepslive.com/s/...g-robotbuilder
