Go to Post Can you restate your observation in a manner that reconciles with physics? - Madison [more]
Unread 09-01-2013, 12:45
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: 54 in cylinder
For those unsure, ask in the Q&A. Personally, I believe the rule is very clear:
G23
A ROBOT’S horizontal dimensions may never exceed a 54 in. diameter vertical cylinder.
You can't lawyer the word "horizontal" or "vertical". My dictionary defines both as being in relationship to the ground.
Horizontal: "at right angles to the vertical; parallel to level ground."
Vertical: "being in a position or direction perpendicular to the plane of the horizon; upright; plumb."
2016: Lake Superior WFFA
Unread 09-01-2013, 12:50
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Re: 54 in cylinder
I guess what might be troubling them is what viewpoint are the rules looking at? Robot-centric or Human-centric? If it is from robot, then the cylinder obviously tilts with the robot; if it is from human(which I think it is) then it stays on the ground even if the robot tilts.
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 09-01-2013, 12:55
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Re: 54 in cylinder
Horizontal and vertical are with respect to the field. For reference, the carpet is horizontal; the alliance station walls are vertical. FRANK the robot shown in <G23> is tilted, but the cylinder is still based from the floor.
Horizontal is horizontal, vertical is vertical, regardless of the robot's orientation.
Hi!
Unread 09-01-2013, 12:57
Re: 54 in cylinder
The view point doesn't matter. Horizontal and vertical are constants, defined with respect to level ground. If you lay on your back on the floor, do you suddenly say that the floor is vertical and the walls are horizontal, just because your perspective has changed?
Unread 09-01-2013, 13:03
dodar's Avatar
Re: 54 in cylinder
Laying down and looking out of your own eyes, then yes the floor is now vertical and the walls are horizontal because that is your perspective. But looking at it in the perspective of someone else looking at a robot, then no it never changes because your perspective isnt changing when the robot moves.
Unread 09-01-2013, 13:43
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: 54 in cylinder
This needs to be asked in Q&A, because FIRST has ruled differently in different years. In 2008, the cylinder was vertical regardless of robot orientation, but many years they have ruled that incidental excursions due to transient conditions such as tilting or being off-balance was not a violation of the rule. With the variety of hanging styles I expect to see this year, clarification is necessary. Would a robot be penalized if it briefly swings outside the cylinder during a winching process from the 1st to the 2nd level of the pyramid? How would that even be determined?
The BUMPER ZONE is also ruled a horizontal plane, but last year they had to modify it to be in relation to the robot's stable driving orientation because of bridges and barrier crossing. I expect a similar interpretation may be necessary this year due to climbing rules.
Unread 09-01-2013, 14:32
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Re: 54 in cylinder
Interesting thought, as when a similar field vs. robot question was asked on the Q&A last year, the response specifically defined "vertical" as in relation to the robot. In fact, virtually all such questions with regard to both orthogonal axes were deemed to be in relation to the robot that year, and in several others I can remember offhand.
Note that this is not to say that 2013 will be the same as 2012 or any other year, only to point out that the GDC has written in similar ambiguity in the past and ruled it robot-centric. It was really the only logical approach for many of the 2012 questions; this is significantly more ambiguous.
Unread 09-01-2013, 14:38
Re: 54 in cylinder
The two rules were written quite differently:
2012:
G21
Robots may extend one appendage up to 14 in. beyond a single edge of their frame perimeter at any time.
2013:
G23
In 2012, they defined the constraint with respect to the robot - 14 inches past the frame perimeter. This year, it's defined with respect to horizontal and vertical, which I take, by their very definitions, to be constant with respect to a level floor, which is another way of saying constant with respect to the local gravity field - for all practical purposes, they don't change as the robot orientation changes, for all games played here on Earth. If you play a game out in the middle of space, you might have a different answer .
Unread 09-01-2013, 14:47
Siri's Avatar
Dare greatly
Re: 54 in cylinder
2012:
2013:
I do not believe that anyone referencing 2012 is referring to G21 (certainly I'm not). The questions last year were almost all about the allowable height and width with respect to the floor while you were on the bridge or barrier. Numerous Q&A questions on these subjects even led to updating the manual wording itself. This year's situation, where again the robot is expected to climb an inclined object/traverse a barrier, are quite similar in that respect.
Unread 09-01-2013, 16:04
Hazzerd Hazzerd is offline
FRC #0250
Hazzerd is an unknown quantity at this point
Re: 54 in cylinder
I believe that its relation to the robot but this question has been brought up by my team members.
Unread 10-01-2013, 09:23
ScottOliveira ScottOliveira is offline
FRC #3455 (Carpe Robotum)
ScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really nice
Re: 54 in cylinder
This has been answered in the Q&A Q15:
The vertical cylinder specified in G23 is not coupled with the ROBOT's orientation and is always vertical.
Unread 10-01-2013, 23:52
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: 54 in cylinder
This is highly worrisome. What if you are a 60" tall robot and you are tipped over (maybe you fall off the tower). Do you get a technical foul? By this ruling, yes, absolutely you do. I feel like that would be adding extreme insult to injury, though and I doubt intended.
Unread 11-01-2013, 00:11
Nuttyman54's Avatar
Mentor, Tactician
Re: 54 in cylinder
In 2008, this was exactly the case, with similar rules for an 80" cylinder. If you fell over and were over 80", you got a penalty. It stunk, but that was the rules. If it isn't intentional however, I don't believe they will assess the TECHNICAL FOUL for it this year (yes, I know it says "continuous", but I'm hard pressed to think that referees would assess it as such, especially if you e-stop).
I might have missed it, but I also don't see the rule that says you can't force an opponent into a penalty like they have had in previous years...
Unread 11-01-2013, 01:14
AKA: Simon Bohn
Re: 54 in cylinder
Our team picked up on the lack of forced penalty rule as well.
I think this requires some Q&A/update based fixing with the forced penalty rule. Only thing I can think of that would cover it is the head refs ability to assign red and yellow cards at their discretion for egregious behavior.
Technically this year it is an equally valid strategy to stack discs on your opponents to force them into penalties. There are many teams that say 'if it is a legal way to score it's a way to score'. Other teams would say this is against their honor code (I know we would never do it). If this kind of thing isn't fixed by the regionals there is going to be lots of unnecessary controversy.
On the original subject of the cylinder, someone should make sure the GDC knows the full ramifications of the rule and doesn't want to make any changes to the 'if a robot is tipped' rule considering how tipping a robot now could potentially create a technical foul.
Unread 11-01-2013, 07:40
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
Re: 54 in cylinder
I think this is far from obvious as well.
I looked back at 2010 breakaway and found an 84" cylinder that year. I really doubt the GDC wanted teams to become 84" ball blockers--they likely figured many people would tilt while climbing and would still need to reach up the 84" to the bar. that would imply they felt the cylinder tilts with the robot.
I also don't see how that picture clarifies the OP question since that robot is not clearly tilted.
I think I'm right at 50:50 on this one...
EDIT:
answered:
Q. Is the 54 inch envelope diameter (figure 3-5) orientation sensitive ie is its axis always vertical regardless of the robots axis ie such as when the robot climbs?
A. The vertical cylinder specified in [G23] is not coupled with the ROBOT'S orientation and is always vertical.
Q. Rule G22 places height restrictions "in relation to the ROBOT." Does this apply to G23 (horizontal restrictions)? When climbing the pyramid, extending an appendage "out" from the robot but "up" in space might extend past the cylinder if it is taken relative to the robot, as opposed to the ground.
A. The height requirement in [G22] is relative to the ROBOT. The horizontal volume requirement of [G23] is relative to the FIELD (see answer to Q15 ).
Last edited by lcoreyl : 11-01-2013 at 08:01. Reason: oops should have searched Q&A better...
