Go to Post Haters gonna hate; kill 'em with kindness. - Taylor [more]
Unread 09-01-2013, 13:11
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
Cannot allocate an object of type 'Command'
Guys,
I think I understand why this is throwing an error, but I am looking for the correct way to do this. In Brad Miller's last Robot Builder video on youtube he writes the following java code:
autonomousCommand = (Command) autonomousModes->GetSelected();
Unfortunately, if you write the same code in C++ you get the following error:
C:/WindRiver/workspace/TestProject/Robot.cpp: In member function `virtual void Robot::AutonomousInit()':
C:/WindRiver/workspace/TestProject/Robot.cpp:40: error: cannot allocate an object of type `Command'
C:/WindRiver/workspace/TestProject/Robot.cpp:40: error: because the following virtual functions are abstract:
C:/WindRiver/vxworks-6.3/target/h/WPILib/Commands/Command.h:79: error: virtual void Command::Initialize()
C:/WindRiver/vxworks-6.3/target/h/WPILib/Commands/Command.h:84: error: virtual void Command::Execute()
C:/WindRiver/vxworks-6.3/target/h/WPILib/Commands/Command.h:95: error: virtual bool Command::IsFinished()
C:/WindRiver/vxworks-6.3/target/h/WPILib/Commands/Command.h:101: error: virtual void Command::End()
C:/WindRiver/vxworks-6.3/target/h/WPILib/Commands/Command.h:114: error: virtual void Command::Interrupted()
C:\WindRiver\vxworks-6.3\host\x86-win32\bin\make.exe: *** [CommandBasedRobotTemplate/Debug/Objects/TestProject/Robot.o] Error 1
The idea is to cast to the "Command" type in order to be able to set autonomousCommand equal to the output of a SelectableChooser object (which is set by the user clicking on the desired command on the Smartdashboard) - which is then the command that gets run in autonomous.
Any thoughts? Thanks in advance.
- Bryce
P.S. Here's the complete code in Robot.cpp
void Robot::RobotInit() {
	RobotMap::init();
	// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=CONSTRUCTORS
	driveTrain = new DriveTrain();
	elevator = new Elevator();
	wrist = new Wrist();
	claw = new Claw();
    // END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=CONSTRUCTORS
	// This MUST be here. If the OI creates Commands (which it very likely
	// will), constructing it during the construction of CommandBase (from
	// which commands extend), subsystems are not guaranteed to be
	// yet. Thus, their requires() statements may grab null pointers. Bad
	// news. Don't move it.
	oi = new OI();
	lw = LiveWindow::GetInstance();
	// instantiate the command used for the autonomous period
	autonomousModes = new SendableChooser();
	autonomousModes->AddDefault("Deliver Cylinder", new DeliverCylinder());
	autonomousModes->AddObject("Awesome Autonomous", new AutonomousCommand());
	smartDashboard->PutData("Autonomous Modes", autonomousModes);
void Robot::AutonomousInit() {
	if (autonomousCommand != NULL) autonomousCommand->Start();
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
