Go to Post I have postulated a theory that it is due to a resonance between gravity waves and the color purple. - petek [more]
Unread 05-01-2013, 19:15
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
LabVIEW install error
Hello -
I'm getting the error "NI USI 2.0.0 Error 1304. Error writing to Gembox.Spreadsheet.dll". When I select retry, I'm given the error 2350. I've run the installer as administrator, on x64 Windows 7. Any assistance?
Dom
Unread 05-01-2013, 20:50
FRC #0023 (PNTA)
Rookie Year: 1620
Re: LabVIEW install error
To any teams having this issue, copy the contents of the LabVIEW 2013 install cd to a folder on your desktop. This seems to have solved the issue.
Dom
Unread 08-01-2013, 00:20
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
I am getting a generic error, I have no info past that, any sugestions? I am following the install instructions exactally. The error says:
An error occured while installing LabVIEW 2012. Do you want to continue installing the remaining products?
Does anyone think that I have somthing running on my PC in the background that is causing this error? I have tried installing over last years software and a clean install. I do not know where to go from here, any help would be apprciated. Thank you.
Unread 08-01-2013, 09:57
When does this error appear? What else does the screen show? What was the installation process doing immediately before it happened?
Unread 08-01-2013, 10:52
Kevin Fort Kevin Fort is offline
no team (Team NI)
Kevin Fort is an unknown quantity at this point
Do you have any antivirus software running on your machine that might be interfering? Make sure you are an administrator when installing (on some machines you also have to right click setup.exe and select Run as Administrator).
Unread 08-01-2013, 12:41
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
This error apears at the end of each part of the install, right after the overall progress bar is at 100%.
Unread 08-01-2013, 12:44
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
This error apears at the end of each part of the install, right before the overall progress bar is at 100%.
Is it possible Norton is doing this? Other programmers on our team have installed with Norton running. I also installed LabVIEW fine on my desktop with Norton running. I will try installing without Norton and post back here.
[Edit] ok, I have installed everything. LabVIEW itself seemst to launch at least, but I do not have the FRC version. I have installed the updates to it, and nothing.
[Edit] My next step is to uninstall all programming software I have on my machine, Netbeans and all the related stuff, LabVIEW, vb2010, and any other stuff, will I need to uninstall this other software?
I can't think of any other conflicts. I have the antivirus turned off all of my NI software uninstalled and no programs running when I try to install LabVIEW.
Unread 08-01-2013, 17:49
no team (Team NI)
Norton has been known to cause some issues with our installers in the past. Do the driver station or imaging tools install correctly? Do you have anything located in this directory:C:\Program Files (x86)\National Instruments\LabVIEW 2012\vi.lib\Rock Robotics\?
You should not need to uninstall old LabVIEW or NetBeans or anything like that.
Unread 08-01-2013, 19:05
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
No, that directory doesn't even exist. This is probally due to me uninstalling all of the NI programs on my PC. None of the software installs without an error message at the end after the 100% mark has been passed and the installer returns to the main install screen (the one with the 8 programs to install) this is where the actual error message shows up, AFTER the secondary install screen closes.
Unread 08-01-2013, 20:30
Wolfram Wolfram is offline
FRC #1918
Wolfram is an unknown quantity at this point
Hi, I'm having the exact same problem. I'm running Win7 and have disabled firewall/anti-virus software. Really looking for an answer here.
Unread 08-01-2013, 22:41
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
How is your system set up? Do you have 2011 labview installed? Also, what are you using for an antivirus pogram?
Unread 09-01-2013, 10:27
no team (Team NI)
I did some more in depth research on the error you are seeing during installation and it looks like it is related to a dependency on the .NET Framework. LabVIEW 2012 is dependent on .NET 4.0. Did you already have .NET 4.0 installed before running the LabVIEW installer? If not LabVIEW should install it for your first and then prompt for a reboot. If you don't reboot there you can run into issues.
Unread 09-01-2013, 14:08
Skyehawk's Avatar
Nuts N' Bolts
AKA: Skye Leake
I dont think that is .NET 4.0 has been updated by windows update as well as repaired by me. Is this what you ment?
Also an interesting thing happened. I ran the DS install and the DS installed fine. I am wondering if I should try to install all of the components seperatly.
Unread 09-01-2013, 18:41
no team (Team NI)
Can you confirm that this registry key HKLM\Software\Microsoft\NET Framework Setup\NDP\v4\Full (Install-Value) is set to 1. This is the registry key that we use to confirm that the full .NET 4.0 framework is installed. I would only expect you to see the error while installing the components from the DVD.
Unread 09-01-2013, 22:58
kennethdharmon2 kennethdharmon2 is offline
FRC #1288
kennethdharmon2 is an unknown quantity at this point
I'm having a similar problem. When installing LVFRC2013, I get the prompt to install .Net Framework 4.0.
I select OK, and then get a prompt that says an error occurred while installing .Net Framework 4.0, reboot and try again. I follow the instructions, but get the same results.
I was able to check and see that I am running .NET Framework 4.0 Client, not the Full version. So I searched the DVD and found the full version, dotNetFx40_Full_x86_x64.exe, but this doesn't appear to install successfully.
I'm running Windows XP Pro, SP3, Any Ideas on how to solve the problem, so that I can then begin to install the software.
Thanks
