Go to Post If your prototype works perfectly, you've been working on it too long. - Blair Frank [more]
Unread 09-01-2013, 14:08
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: [FTC]: Set Screws Suck!!!
Originally Posted by JesseK View Post
File down the tip of the set screw, or replace the set screw with a machine bolt. This spreads the stresses of the set screw out more, making the set screw less likely to slip in the first place.
Actually, I would not replace the set screw with a machine bolt, primarily because the machine bolt doesn't have a finished end, unlike a set screw, which (most probably) has a machined cup point, which is designed to really grab a shaft. In certain applications, it is advisable to file down the tip of the set screw, but I do not believe that this case is one of them, unless of course you are using a flat tip set screw.
The one time I used a machine bolt (Socket Head Cap Screw, 10-32, 2", Black Oxide Steel) as a set screw, I completely destroyed the tip (the metal in the bolt was too soft).
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
