Go to Post FIRST opened a door and I walked through it. - Erin Rapacki [more]
Unread 09-01-2013, 13:22
GrimmReaper's Avatar
GrimmReaper GrimmReaper is offline
FRC #2046 (Bear Metal)
GrimmReaper is on a distinguished road
Re: Sending SmartDashboard Data to cRIO without pressing [ENTER] key
I was just testing last night with the 2013 SmartDashboard and it seems like i still have this problem? I couldn't seem to get a new value in a text field to the robot without pressing enter. Has anyone else tried this yet? is there another way to get the value to update? I would LOVE to be able to run both smartDashboard and the driver station on one computer AND update values without disabling the robot :-)
Let me know if there's a solution i'm not aware of,
thanks!
Unread 09-01-2013, 15:35
AKA: Brad
#0190 ( Gompei and the Herd)
For the Enter key problem, if you select another text field with the mouse, it will commit the value in the text field you just changed. So type in the numbers, don't hit enter, instead click with the mouse in another field.
That will commit the change to the field.
Brad
Brad Miller
Robotics Resource Center
Unread 16-01-2013, 04:23
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Instead of using the Dashboard to send data to the cRIO, we use the debug console instead. Our FRC library has a module that enables us to interact with the cRIO using the debug console. Basically, the cRIO program provides a command line interface printing a command line prompt on the debug console. Then the user can type the command to be executed with command line parameters. For example, the following shows an excerpt on what the debug console looks like:
Console-> help
q       - Exit console mode
help    - List commands and info about them
listobj - List registered command objects
listvar - List variables and info about them
get     - Get the value of a variable
Console-> get DriveBase.DriveKp
Kp = 0.5
Console-> set DriveBase.DriveKp 0.55
Console->
Unread 18-01-2013, 17:09
According to the Software Notes the version of SmartDashboard released today (in the C++ and Java updates) will commit values when you tab.
Unread 18-01-2013, 19:49
AKA: Brad
Yup, it was a bug where it was working in the LiveWindow (test mode) but not in the regular SmartDashboard widgets. Should be fixed now, so just click in another field or otherwise get the modified field to lose focus and the value will commit.
Also, notice that we'll automatically register all your actuators and sensors for test mode so that you can see values and manipulate them without having to write any other code.
Brad
Brad Miller
