Go to Post FIRST is kind of like charity work... you are, even if only in some small way, helping our future just a little bit, and you get a great feeling from it. Even if you are just ringing a bell (or clapping MOE sticks together), you're helping. - Amanda Morrison [more]
Unread 09-01-2013, 16:49
ctccromer's Avatar
ctccromer ctccromer is offline
Animus
AKA: Tucker Campbell
FRC #3753 (Bulah Bots)
ctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to all
Setting up the D-Link radio?
I installed the FRC Bridge Configuration Utility program, but whenever I try and configure it, I'm told to reset. I reset it multiple times but get the same error every time
Set the team number and a custom WPA Key, Radio: "DAP1522 RevB" and Mode: "2.4GHz Access Point". The mode on the D-Link itself (by the power plug and reset button) is also set to AP 2.5 GHz, the power is plugged in all the way, and the ethernet cable is attached between my laptop and the D-Link router.
The error says:
Bridge configuration failed: Illegal firmware version found (2.02)
Please reset the bridge and try again
Team 3753 BulahBots
