Go to Post Our robot weighed 168lbs..... bring it on Trimspa!!! - slickguy2007 [more]
Unread 09-01-2013, 20:27
Avihu Avihu is offline
FRC #4661
Avihu is an unknown quantity at this point
FIRST Cim problem
Hey we just ran our *new* chariot and we FAILED..
the chariot ran very nicely for almost a day when we decided to test who much weight can it carry.. the answer: Not that much...
than when we tried to run it without the weight one side of the chariot (one cim) got jamed or something and then it started to run OK again and then jamed again and it just repeat it self and we don't know what to do.. we might have broke a Cim already..?
and if not.. what to do??
Unread 09-01-2013, 20:29
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: FIRST Cim problem
How is the CIM geared to the wheels? Did you grease the gearboxes? What control inputs are you giving it when you see the failure? What does the motor controller think you're telling it to do?
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 09-01-2013, 20:41
FRC #4661
toughbox, yes and i didn't undeestand the last one..
Unread 09-01-2013, 20:44
AKA: Nathan Hui
Is software telling the motor to go 100% forward, 100% backwards, or what? And what does the motor controller status light say it's getting? (Basically, is the motor controller and control system working?)
To add on to my initial questions, when the robot is off and unplugged, can you turn the problematic drivetrain by hand? How many turns, and how hard is it to turn?
Nathan Hui
FTC 4950, 6038
Unread 09-01-2013, 20:47
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
We had a slight problem with the gearbox jamming. When we inserted the bearings, a freshman was somehow able to bow the mounting plate a little. As a result, the gearbox would jam when tightened.
We flipped the plate around, and haven't been troubled so far.
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
Unread 09-01-2013, 20:48
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Sounds more like low battery power is having controllers cut out. If you have a battery with one sick cell, the charger may tell you it has finished charging, but the battery is incapable of delivering what the control system needs for your heavy load testing.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
AKA: Nathan Hui
@Ankit: Not the OP's problem - he's got occasional jamming, not continuous.
Nathan Hui
FTC 4950, 6038
Unread 09-01-2013, 20:52
FRC #4661
the problematic rail is kind of hard to roll by hand and when rolling one way it makes a really *not good* sound that the other does not make..
Unread 09-01-2013, 20:53
Have you opened up the gearbox and looked inside? Something might have gotten loose in there and be jamming gears as it jostles around.
Unread 09-01-2013, 20:56
AKA: Nathan Hui
I would definitely look at the gearbox. If you can, simply replace it. Otherwise, do what Eric says. If you can't figure out what the problem is, try replacing all of the grease. Make sure that there aren't any dings on the gears. Make sure the bearings are good. Since your problem was (according to your description) intermittent, I doubt it's the plates, but now that it apparently isn't intermittent anymore, Ankit's problem may have a lot more commonality to your problem than I initially thought.
As you are replacing the gearbox, run the CIM motor separate from the gearbox. It should spin up pretty nicely. If it doesn't, the CIM's shot. Doesn't mean the gearbox isn't shot too, so keep checking both.
Nathan Hui
FTC 4950, 6038
