Go to Post Uhh... we were supposed to be building a robot? *looks at giant wooden Trojan Rabbit in the corner that was built instead for the past 6 weeks* Whoops... - Adam Richards [more]
Unread 09-01-2013, 19:21
jminer19363's Avatar
jminer19363 jminer19363 is offline
FRC #3135 (Robotic Colonels)
Team Role: Electrical
jminer19363 will become famous soon enough
Wheelless Robot?
So my team is debating on whether to have wheels or not. In the rules, it says, "The Robot must include all of the basic systems required to be an active participant in the game - power, communications, control, mobility, and actuation."
Does climbing count as mobility or would the lack of wheels be illegal?
Unread 09-01-2013, 19:27
Littleboy Littleboy is offline
FF: The Yellow Alliance (TYA)
Littleboy has a spectacular aura aboutLittleboy has a spectacular aura aboutLittleboy has a spectacular aura about
Re: Wheelless Robot?
That would be legal.
There was a question in the QA about it.
R01
Q.Do we need a drive-train?
A.There are no Rules that require a drive base.
Unread 09-01-2013, 19:29
sebflippers sebflippers is offline
FRC #2914
sebflippers will become famous soon enoughsebflippers will become famous soon enough
It should be fine, but it doesn't sound like a very good idea.
Unread 09-01-2013, 20:08
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Sure, it might be legal as long as your bumpers are in the legal bumper zone.
And make sure that the base of your wheelless robot isn't metal, metal touching carpet isn't allowed.
But a driveless robot won't do very well. An alliance won't want that, even if you could just drive around you become a defense robot.
Unread 09-01-2013, 20:18
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
But then I can use my CIMs for much more important tasks!
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 09-01-2013, 20:25
Elgin Clock's Avatar
FRC #0237 (Black Magic)
If the only thing you wanted to do in a match is CLIMB, this would be a good way to save weight.
Unread 09-01-2013, 20:36
Billfred's Avatar
Billfred Billfred is offline
This. And I think a 30-point contribution will tip the scales in the vast percentage of matches.
Unread 09-01-2013, 20:46
But since with autonomas, we start out next to the pyramid, we can climb and get easy 30 points with endgame, which WILL make an alliance want that.
Unread 09-01-2013, 20:49
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Can you site the rule for this?
Unread 09-01-2013, 20:52
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
I believe that the rule they are citing is <R06> which states...
Originally Posted by <R06>
Traction devices may not have surface features such as metal, sandpaper, hard plastic studs, cleats, or similar attachments. Traction devices include all parts of the ROBOT that are designed to transmit any propulsive and/or braking forces between the ROBOT and FIELD carpet.
Emphasis mine.
It's up to interpretation, but would a frame be considered a "traction device"?
Unread 09-01-2013, 20:56
More to the point, can a frame damage the carpet?
It's also not terribly difficult to put some plastic on the bottom of a metal frame using countersunk screws or appropriate adhesive.
To answer the original question: If you have designed your robot to play the game in such a way that you do not need to move, I would say that you have satisfied the rules. (I would like to note that I have seen a wheelless robot take the field before, but it's been several years and a slight rule change on the definition of robot since that happened.)
Unread 09-01-2013, 20:58
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Unless the robot's design is meant to be dragged across the carpet, then under no definition of "traction" does the frame become a traction device. However, if the frame sits there during a match, is pushed and causes the carpet to rip then I think the refs will throw a yellow card.
'No wheels' is a perfectly good way to save weight for a flier. So is the properly-dimensioned 'L' shaped robot -- no bumpers needed on half of the robot, so the weight savings is a big plus. We hadn't thought of such a base until we saw it in Q&A.
GitHub
Unread 09-01-2013, 21:17
AKA: Matt B
FRC #1771 (1771)
Compared to another robot that can climb and can ALSO drive around, (at all), the driving robot can provide a small amount of defense and interference.
Unread 09-01-2013, 21:40
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
You would need to cover all external corners, it would have the same amount of bumpers i believe, correct me if i am wrong, it would look like this... same amount of bumpers.
Unread 10-01-2013, 15:28
Tao's Avatar
Tao Tao is offline
AKA: Dana Muenter
FRC #2838 (Eaglebots)
Tao is an unknown quantity at this point
We were debating bumpers on an relatively L-shaped robot on a different thread: http://www.chiefdelphi.com/forums/sh...d.php?t=110770
Any more interpretation on the 'no bumpers needed' comment with regards to the posts on the thread?
On topic though, my team was (jokingly)thinking of making a cube that sits there and then climbs. It would be interesting, although you'd have to be able to touch your pyramid so you don't get bumped out of position without consequence.
