Go to Post We were all rookies once. Some of us still are... - Wayne C. [more]
Unread 09-01-2013, 20:32
Ganondalf Ganondalf is offline
FRC #4665
Ganondalf is an unknown quantity at this point
Where do I find digital module 1?
Im creating a non drive victor motor in the Begin.vi, how to i insert digital module 1, where can i find it? Thanks!
Allons-y!
Unread 09-01-2013, 20:36
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Re: Where do I find digital module 1?
Physically? On your cRIO, it will be module NI 9403. You're digital sidecar should be connected to it via a ribbon cable.
Unread 09-01-2013, 20:37
Digital Module 1 just indicates that the Crio's second slot holds the Digital Module that this motor you're creating will use.
It's the default so you don't even have to specify it.
Unread 09-01-2013, 20:40
FRC #4665
In the Begin.vi, I have everything set up. However, there should be a "digital module 1" connected to my PWM
Unread 09-01-2013, 20:41
FRC #4665
ohhh, gotcha, thanks again!
Unread 10-01-2013, 00:06
Right-click on the Motor Open vi's "Digital Module" terminal and choose Create -> Constant from the pop-up menu. It'll give you an enumerated constant with the choices of Digital Module 1 and Digital Module 2.
As Mark said, though, If you don't wire anything to that terminal, it will default to Module 1. You need to change it to Module 2 only if you have installed a second DIO module in the cRIO and an associated second Digital Sidecar.
Unread 28-01-2013, 14:10
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
I have a related question, if I were to program a single motor and place under Digital Module 2, then this would essentially mean that I am wiring the motor to second digital sidecar which the NI 9403 is in slot 4. Our team has 2 digital sidecars since we have 13 motors on our robot so I am trying to program some of the motors on a second digital sidecar.
Unread 28-01-2013, 14:14
Yes. The second NI 9403 would be in slot 4 on the 4 slot cRIO or slot 6 in the 8 slot cRIO.
I have a related question...
Fine. What is it?
Unread 28-01-2013, 14:46
Thanks
