Go to Post note to self: MUST try harder to be funnier... - dlavery [more]
Unread 07-01-2013, 20:44
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
LabView programs not seeing the RTE
So im trying to update to the current LabView runtime engine to run driver station, cRIO imager, etc. and ive downloaded the RTE from this link
http://joule.ni.com/nidu/cds/view/p/id/3435/lang/en
and im currently using a Windows 7 Home Premium Computer.
but when i run the installer, i replace everything, install, it prompts for reboot, i reboot, but if I try to run any LabView program it still says that it doesnt detect a LabView RTE
If i run the installer again, it says that everything is loaded on and asks if im prompting for an uninstall... so the installer knows its there but the programs cant find it. Help?
Unread 07-01-2013, 21:02
Re: LabView programs not seeing the RTE
Did you download the 64 bit edition? All of the FRC tools are 32 bit.
Try this one http://joule.ni.com/nidu/cds/view/p/id/3433/lang/en instead.
Greg McKaskle
Unread 07-01-2013, 22:26
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Greg McKaskle
i see i see. apparently im the only one in my programmer group with a 64-bit laptop -_-
working great, thanks!
(i thought i tried x32 before, but I think that was 2011 RTE on acci)
e/ All FRC tools keep giving me an error about a missing nivision.dll and a few other dlls
Unread 08-01-2013, 08:29
If you are missing vision, be sure to install the Utilities update if using other languages, or the LabVIEW update if you are using LabVIEW.
Greg McKaskle
Unread 08-01-2013, 17:47
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Greg McKaskle
didnt work. missing nisysconfig.dll
Unread 08-01-2013, 18:55
Kevin Fort Kevin Fort is offline
no team (Team NI)
Kevin Fort is an unknown quantity at this point
Which LabVIEW programs are you trying to run? Do the Driver station or Imaging tool run? Can you post some screenshots of the error you are seeing? Is it possible you are running an older LabVIEW application that would need the older run-time?
Unread 08-01-2013, 20:32
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Nevermind, a friend helped me fix it, thanks!
(for future reference, i was missing the NI System Configuration Runtime)
Unread 09-01-2013, 20:29
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
I had it working... but now its giving me the nicolor.dll error again
Unread 09-01-2013, 20:41
Just for curiosity sake, why aren't you just installing the FRC version of LabVIEW?
You seem to be piecemealing from online instead.
Unread 10-01-2013, 14:45
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
piecemealing?
i already had a previous version of labview from the kop flashdrive but im trying to update it
Unread 10-01-2013, 14:49
I'd suggest doing a clean uninstall/install.
Everything needed is on the KOP stick, the FRC LabVIEW, Utilites, Driver Station updates.
The older KOP version license is expiring.
The LabVIEW versions are different anyway.
Unread 10-01-2013, 17:31
lorem3k's Avatar
lorem3k lorem3k is offline
1 + 1 = 0 (in Z/2Z)
AKA: Andy D.
FRC #1482 (Bishop Grandin Ghosts)
lorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to behold
Uninstall previous versions of LabVIEW, and then install the 2013 system in the following order:
0. LabVIEW 2012 (on the CD in the envelope from the KOP)
1. FRC LabVIEW update for 2013
2. FRC Utilities Update
3. Driver Station Update
You can find the Utilities update, and the other updates, here. The USB drive from last year had LabVIEW 2011, not 2012, so it won't be compatible.
Boo! Bishop Grandin High School / GM Canada / Tenaris
2013 Western Canada - Quarterfinalists (thanks 288/4719) / 2012 GTR West - Quarterfinalists (thanks 188/1075) / 2011 GTR East - Regional Winners (thanks 1114/1503)
Unread 10-01-2013, 18:26
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
Done (kinda... utilities update has no uninstall option) and it still didnt work.
I noticed a desktop icon : "Setup Axis Camera" but when i click on it, it gives me the old runtime error that theres no runtime (except its saying 2011 not 2012...) (i can run everything else fine with nivision.dll errors like drivestation and crio flasher)
