Go to Post ...and then at the end they interviewed this 5 year old on his favorite part (of the fair): "I liked the robot" - Jessica Boucher [more]
Unread 09-01-2013, 15:59
Jared Russell's Avatar
Taking a year (mostly) off
Re: Random autonomous
Originally Posted by pfreivald View Post
You can't interfere with your opponents, and you can't be interfered with, so why do something random when you can instead do the best thing you're capable of?
This isn't strictly speaking true. Yes, there is a center line. But there are still ways to interfere or be interfered with.
Unread 09-01-2013, 16:26
3132MentorMike 3132MentorMike is offline
Set the bar higher than you imagine
AKA: Mike Heimlich
FRC #3132 (Thunder Down Under)
3132MentorMike is a jewel in the rough3132MentorMike is a jewel in the rough3132MentorMike is a jewel in the rough
Originally Posted by slijin View Post
What we've done traditionally is include a rotary binary switch (a more compact version of what Don mentioned) somewhere on our OI or robot, and tie a specific auton routine to each setting using a switch block. By changing the switch's state, we can choose between auton routines on the fly when we need to switch roles for a certain match.
Yeah, this works. We've used a binary-coded decimal switch on the front of the robot so that you can pre-set your autonomous mode AFTER consulting with your alliance partners on the desired strategy.
"Random" doesn't work so well if you are going to interfer with what your alliance partners are going to do.
Unread 09-01-2013, 20:49
pfreivald's Avatar
AKA: Patrick Freivald
Point conceded.
...but it still doesn't justify random actions!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
