Go to Post To go a step further, to be "steam punk", electrics would need to be powered from a steam turbine operated dynamo but electric wiring would still be required to follow all rules as they would apply. - Al Skierkiewicz [more]
Unread 08-01-2013, 21:36
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Java programming of an XBox Controller
How could we use an xbox controller to control our robot?
Does anyone have a drawing of which buttons correspond to what numbers and what axis' correspond to what numbers?
Any help would be appreciated!
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 08-01-2013, 21:41
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Re: Java programming of an XBox Controller
Yes, you could, but I would recommend against it. The Xbox Controller has fairly large (and inconsistent) deadzones around the center of the sticks. The logitech joysticks provide better accuracy.
If you just want the button bindings, scroll to the bottom. Otherwise, you can use this class to simplify things.
 * To change this template, choose Tools | Templates
 * and open the template in the editor.
package org.usfirst.Rotoraptors.controls.hids;
import edu.wpi.first.wpilibj.buttons.*;
 * @author Daniel
public class XboxController {
    private Joystick m_pad;
    public XboxController(int port) {
        m_pad = new Joystick(port);
    public double getLeftX() {
        return m_pad.getRawAxis(LEFT_X_AXIS);
    public double getLeftY() {
        return m_pad.getRawAxis(LEFT_Y_AXIS);
    public double getRightX() {
        return m_pad.getRawAxis(RIGHT_X_AXIS);
    public double getRightY() {
        return m_pad.getRawAxis(RIGHT_Y_AXIS);
    public double getTriggers() {
        return m_pad.getRawAxis(TRIGGERS);
    public double getDpadX() {
        return m_pad.getRawAxis(DPAD_LR);
    public double applyDeadband(int axis) {
        if(Math.abs(m_pad.getRawAxis(axis)) < .1) {
            return 0;
        } else {
            return axis;
    // Creates buttons
    public Button X = new JoystickButton(m_pad, BUTTON_X);
    public Button Y = new JoystickButton(m_pad, BUTTON_Y);
    public Button A = new JoystickButton(m_pad, BUTTON_A);
    public Button B = new JoystickButton(m_pad, BUTTON_B);
    public Button lBumper = new JoystickButton(m_pad, BUMPER_L);
    public Button rBumper = new JoystickButton(m_pad, BUMPER_R);
    public Button start = new JoystickButton(m_pad, BUTTON_START);
    public Button back = new JoystickButton(m_pad, BUTTON_BACK);
    public Button lStick = new JoystickButton(m_pad, LEFT_STICK_PRESS);
    public Button rStick = new JoystickButton(m_pad, RIGHT_STICK_PRESS);
    public boolean getButton(int btn) {
        return m_pad.getRawButton(btn);
    // Axis indexes:
    public static final int
            LEFT_X_AXIS = 1,
            LEFT_Y_AXIS = 2,
            TRIGGERS = 3,
            RIGHT_X_AXIS = 4,
            RIGHT_Y_AXIS = 5,
            DPAD_LR = 6;
    // Button mappings:
            BUTTON_A = 1,
            BUTTON_B = 2,
            BUTTON_X = 3,
            BUTTON_Y = 4,
            BUMPER_L = 5,
            BUMPER_R = 6,
            BUTTON_BACK = 7,
            BUTTON_START = 8,
            LEFT_STICK_PRESS = 9,
            RIGHT_STICK_PRESS = 10;
Which you can call the same way you call regular Joysticks (in regards to where you put it and the information you provide to the method), ie:
    XboxController driverXbox = new XboxController(1);
    XboxController operatorXbox = new XboxController(2);
It also creates the buttons for you so you can keep your OI code cleaner.
driverXbox.A.whenPressed(doSomething());
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 08-01-2013, 21:46
inkspell4's Avatar
How much do said logitech controllers cost!
Unread 08-01-2013, 21:52
F22Rapture's Avatar
AKA: Daniel A
The Attack 3s should have come with your Rookie KoP... if not, $20-$25
If you're dead-set on using a gamepad, the Logitech F310 is about the same price, and also has both thumbsticks at the bottom of the controller so tank drive is less awkward. And they seem to have less deadzone than the Xbox controllers.
- Wernher von Braun
Unread 08-01-2013, 21:59
inkspell4's Avatar
How big is the deadzone on an xbox controller?
Unread 08-01-2013, 22:12
F22Rapture's Avatar
AKA: Daniel A
Depending on the controller, 15-20%
- Wernher von Braun
Unread 08-01-2013, 22:14
inkspell4's Avatar
Have you personally tested these and which is this info based on.
Unread 08-01-2013, 22:37
F22Rapture's Avatar
AKA: Daniel A
I pulled up Xpadder and looked at the raw ouput. Mine was about 18%. Some seem to have more, some less.
- Wernher von Braun
Unread 08-01-2013, 23:03
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Here's our XBoxController class:
https://github.com/team1306/Badgerbo...ontroller.java
Unread 09-01-2013, 16:12
inkspell4's Avatar
Originally Posted by cgmv123 View Post
How effective has it been for you guys to use an xbox controller
Unread 09-01-2013, 18:07
cgmv123's Avatar
AKA: Max Vrany
Very. We've had no issues with it.
Unread 09-01-2013, 21:13
inkspell4's Avatar
Do you feel the deadzones affected your playing
Unread 09-01-2013, 22:51
cgmv123's Avatar
AKA: Max Vrany
We don't really use the joysticks (we do our driving with the Attack 3's), but when we do we just have extra wide deadbands. We've found our controller sometimes doesn't return exactly to zero.
