Go to Post FIRST is one strange world.... - Wayne C. [more]
Go Back   Chief Delphi > Technical > CAD
Unread 07-01-2013, 16:35
NotSoSiniSter NotSoSiniSter is offline
NotSoSiniSter is on a distinguished road
Where is the full CAD of the field for the 2013 game?
I've been on the hunt all morning for the CAD of the field. I don't care if its a Autodesk or SolidWorks file. I have both. I already have one of just the pyramid. Are they out yet or am I just not looking hard enough?
Unread 07-01-2013, 17:25
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: Where is the full CAD of the field for the 2013 game?
Autodesk should have a .STEP version of the KoP and Field on their Educational Community Website.
http://www.chiefdelphi.com/forums/sh...8&postcount=13
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 08-01-2013, 12:49
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
As Nathan indicated there is an Autodesk Inventor 2013 version of the field and a STEP version. I have atttached the STEP version to this post.
The major components are modeled such as the pyramids, goals, etc.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 08-01-2013, 14:02
Thanks this will help out a lot for the time being. But is there an official 2013 field drawing available?
Thanks.
Unread 08-01-2013, 14:38
AKA: Nathan Hui
Strictly speaking, I don't think an "official" version exists, primarily because FIRST relies (and has done so in the past) on Autodesk and PTC to provide CAD models of the KoP and field. I would regard those as the most official. However, the drawings provided by FIRST and the GDC are the official specifications for the field, barring adjustments in the Q&A, should there be any.
Nathan Hui
FTC 4950, 6038
Unread 08-01-2013, 16:41
Aren Siekmeier's Avatar
on walkabout
It's silly to think that there is not an official version that FIRST has used in design and production of the field in the first place. Where do you think they get their technical drawings from? Why they rely on PTC and Autodesk to remodel everything, instead of just releasing their own STEP, is beyond me.
Unread 08-01-2013, 17:22
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
The 3rd level is now at the correct height but the corner tubes at the top are not correct. First image is the latest STEP file, second is the image from the field drawings.
Unread 08-01-2013, 19:14
on walkabout
Can anyone shed light on whether the Pro/E version of the pyramid has these dimension issues? It appears that somehow the Autodesk version is still consistent with the published drawings (I haven't checked to be sure), so perhaps it is. I haven't yet been able to import the Pro/E version into Solidworks, so if anyone who has seen the Pro/E version could check this out, that'd be appreciated.
Unread 08-01-2013, 23:36
robobonobo robobonobo is offline
robobonobo is an unknown quantity at this point
The Autodesk Inventor model did correct the height of the pyramids per the other post discussion. (Thanks a ton for the quick turnaround Phil!). The current discrepancy is actually the base width of the pyramid being ~90" instead of 94. This lowers the intersection of the tubing make the top appear taller. I mistakenly thought the angle was wrong (60° instead of 68°) but I wasn't taking the projection in the angle measurement. This is noted in the other pyramid discussion thread.
Unread 09-01-2013, 21:33
Jared Russell's Avatar
Taking a year (mostly) off
The ProE version appears to match the drawings and manual.
Unread 10-01-2013, 00:13
on walkabout
Since I had enough difficulty with the Inventor version, then failing to import the Pro/E version to Solidworks, then with installing Pro/E, then with getting it to render anything at all.... I figured I'd post a .step of the Pro/E exported from Pro/E for the rest of us looking for accurate pyramid CAD. This one also has complete alliance stations.
A STEP of the Pro/E version of the field can be found here.
Unread 10-01-2013, 12:41
I was headed down that same path... Thank You!
Unread 11-01-2013, 23:24
roach1051's Avatar
roach1051 roach1051 is offline
Go Boilers!
AKA: Jack Roach
FRC #1051 (Technical Terminators)
roach1051 is on a distinguished road
I tried to load the ProE step file you posted, but it is so large that my Inventor 2011 installation crashes for lack of virtual memory. Can you post a step of only the pyramid?
Precision is for amateurs, custom fit is for professionals
Unread 13-01-2013, 21:03
Pyramid STEP file attached.
STEP files may lose their constraints when opened, so, in the browser, select all parts or assemblies and then click Grounded.
Phil Dollan
Autodesk Inc.
Unread 23-01-2013, 19:05
Itamar's Avatar
Itamar Itamar is offline
FRC #1943 (NeatTeam) & FRC #4590 (GreenBlitz)
Itamar is an unknown quantity at this point
Hey Phil, just to make sure 100%, is that last Pyramid STEP file you posted accurate?
