Go to Post You guys must sponsor that one team on The Fosters! - Tyler Olds [more]
Unread 05-01-2013, 21:59
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Where to Start in Autonomous
G6 TEAMS may preload White DISCS in or on the ROBOT before the MATCH.
A. If the ROBOT is in contact with any carpet outside its AUTO ZONE, the ROBOT may preload up to three (3) DISCS.
B. Otherwise, the ROBOT may preload up to two (2) DISCS.
Thoughts?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 05-01-2013, 22:05
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Re: Where to Start in Autonomous
The auto zone is on the side of the line that contains the pyramid, correct? (blue zone, blue pyramid)
If so, I think it basically depends on how you design in regards to your height, as you can go higher when in your auto zone. IMO this makes it much more appealing to design a shorter robot.(that is, if certain shooter prototyping can produce far enough distances...)
Unread 05-01-2013, 22:07
Kristian Calhoun's Avatar
Kristian Calhoun Kristian Calhoun is offline
Celebrating 20 years of 25
FRC #0025 (Raider Robotix)
Kristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond repute
Send a message via AIM to Kristian Calhoun
Correct:
Originally Posted by 6.1 ULTIMATE ASCENT Terms
AUTO ZONE: an area on either end of the FIELD bounded by the ALLIANCE WALL, FEEDER STATIONS, LOW GOAL, GUARDRAILS, and the nearest AUTO LINE.
Raider Robotix: Home | Twitter | Facebook | Instagram
Brunswick Eruption: Home | Twitter | Facebook
Unread 05-01-2013, 22:09
Gregor's Avatar
Correct. Anything behind the line (and the pyramid) means you can hold 3 disks, anything infront of the line limits you to 2.
<Since 2011
AKA: Scooby
Originally Posted by Kristian Calhoun View Post
Correct:
Alright, I had plenty of initial confusion and was erring on the side of caution in regards to that, so that's good.
Unread 05-01-2013, 22:18
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Not entirely true. Compare these rules:
<G05>
When placed on the FIELD, each ROBOT must be:
D. contacting its PYRAMID.
<G06>
<G22>
ROBOT height (as defined in relation to the ROBOT) must be restricted as follows during the MATCH:
A. If in contact with the carpet in its AUTO ZONE and/or its PYRAMID, 84 in.
Theoretically, you could start on the corner of your Pyramid, touching it, your Auto Zone carpet, and non-Auto Zone carpet ...allowing you to be 84" tall and have 3 pre-loads. So the 2 vs. 3 preload issue is not a direct decision based on robot height. (It might be based on whether you can successfully score from the required position, but 84" and 3 preloads are not mutually exclusive.)
Unread 09-01-2013, 21:43
Gregor's Avatar
So what do initial strategy sessions say. Where will your team be starting? Where do you think most teams will be starting?
<Since 2011
Unread 09-01-2013, 22:09
Bonekiller407's Avatar
Bonekiller407 Bonekiller407 is offline
AKA: Dakota Masson
FRC #0240 (T.E.M.P.E.S.T.)
Team Role: Student
Bonekiller407 is an unknown quantity at this point
Ok this is kinda off topic but people are on this post so can someone tell me how to make a New thread I deal really dumb because I can't figure it out. Thanks
Unread 09-01-2013, 22:41
Click the purple logo at the top left of each CD page. This takes you to the "Forums" page, which lists all the forums and most of the subforums that CD has to offer. Select the one that your topic will fit best under (hint: probably not "General" at this point), check to make sure someone else hasn't asked the same question (check in "General" as well, just to make sure), and click the "New Thread" button near the top of the thread listing.
Unread 09-01-2013, 23:36
jpkelly26 jpkelly26 is offline
FRC #1807
jpkelly26 is an unknown quantity at this point
The way I interpret this is if you want to start with three discs you need to be a. touching the pyramid and b. partially behind the pyramid, which if you need to line up your shot (i.e. not move before shooting) it makes it difficult to shoot at the high goal since you would have to shoot through the pyramid or potentially "around" it. If you can't reach the high goal with these constraints then I would think you are better off with two disc shooting the high goal from a closer range then three discs at the middle goal from further away. Both would potentially get you 12 points.
Of course depending on your robot your mileage may vary :-)
