Go to Post I feel like we should get karma points for "Inspiration via Q&A". - JVN [more]
Unread 09-01-2013, 22:19
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: Very New and Very Clueless!
Most of the same basic constructs you'd find in a text-based language are present in Labview, they're just more visual. I recommend learning one language at a time so you don't get confused by different terminology. Once you get the basics of programming down in one language, they transfer pretty well. For example, a Select block in Labview is the functional equivalent of an if/then/else statement in C. The only weird thing about Labview is using dataflow through the wires rather than passing variables around explicitly.
The frcmastery videos start pretty basic and work up. NI.com also has a lot of good resources for Labview.
