Go to Post Although I've never oxy welded myself, I know it is doable - jamie_1930 [more]
Unread 09-01-2013, 16:45
SoulStealer16's Avatar
SoulStealer16 SoulStealer16 is offline
FRC #3654 (TechTigers)
SoulStealer16 is an unknown quantity at this point
The Pyramid Goal...
Does anyone know how big the goal on top of the PYRAMID is??
"Let music influence your mind,
your mind influence your actions,
and let your actions influence others." -Anonymous
"Before you die...make sure you change a small part of the world for the better." -Me
Unread 09-01-2013, 16:47
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: The Pyramid Goal...
See pg 17 in the game manual...
Section 2.2.3
Located atop each PYRAMID is a PYRAMID GOAL. The PYRAMID GOAL is a polycarbonate and metal framed
“basket” that is a 23 5/8 in. square that is 2 3/4 in. deep. Rising out of the center of the PYRAMID GOAL is a 20 in. tall,
1 1/2 in. diameter post. Hanging from the top of the post are chains (Ace Hardware P/N: 5365283) to help dampen the
DISCS as they enter the PYRAMID GOAL.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 09-01-2013, 16:48
vinnie's Avatar
vinnie vinnie is offline
FRC #3309 (Friarbots)
vinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond repute
Hate to be the guy that tells you to read the manual but it is under section 2.2.3
Located atop each PYRAMID is a PYRAMID GOAL. The PYRAMID GOAL is a polycarbonate and metal framed “basket” that is a 23 5/8 in. square that is 2 3/4 in. deep. Rising out of the center of the PYRAMID GOAL is a 20 in. tall, 1 1/2 in. diameter post. Hanging from the top of the post are chains (Ace Hardware P/N: 5365283) to help dampen the DISCS as they enter the PYRAMID GOAL.
Student (3309) 2010-2013
Mentor (597) 2014
Mentor (3309) 2013-Present
Unread 09-01-2013, 16:50
AKA: Nathan Hui
http://www.chiefdelphi.com/forums/sh...threadid=79490
OP, please read.
Nathan Hui
FTC 4950, 6038
Unread 09-01-2013, 16:56
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
The manual is a good source for a lot of information. However, I often find it lacking enough details about specific field elements to answer all my questions. If you need exact specifications, I suggest looking at the game field drawings located here: http://www.usfirst.org/sites/default...c_Drawings.pdf
Don't look at the team drawings, because those often deviate from the real field dimensions to make it "easier" for teams to build them.
Unread 09-01-2013, 16:57
We'd all read the manual. We were just forgetting where we saw that topic in. Thank you all for the helP
Unread 09-01-2013, 22:59
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
CTRL + F
"pyramid goal"
instance # 3
