Go to Post Heaven forbid. A hexed Vex. - Warren Boudreau [more]
Unread 09-01-2013, 23:32
TheGuyz TheGuyz is offline
FRC #2443
TheGuyz is an unknown quantity at this point
Pyramid rule clarification
Do the levels of the pyramid extend outside of the pyramid frame? With the exception of level 0
Unread 09-01-2013, 23:38
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: Pyramid rule clarification
Yes. It is implied that the levels of the pyramid extend to the full extent of the field, and no rules as of yet have nullified that interpretation.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 09-01-2013, 23:45
FRC #2443
Okay thanks. We were also wondering when does the next level start above each bar?
Unread 10-01-2013, 00:00
Yankeefan181's Avatar
Yankeefan181 Yankeefan181 is offline
1540 Co-Captain
AKA: Tucker
FRC #1540 (Flaming Chickens)
Yankeefan181 is a jewel in the roughYankeefan181 is a jewel in the roughYankeefan181 is a jewel in the rough
Slightly unrelated, but I thought this was a good thread to put this on. Just a heads up to everyone, FIRST has actually updated the rules without telling anyone. The initial rules that came out right before kickoff had in (in section 3.2.4.2):
"A ROBOT has CLIMBED its PYRAMID if it contacts the PYRAMID in A. sequential order (Level 0, 1, 2, 3) during ascent and B. no more than two (2) Levels simultaneously."
Since the floor is not counted in the definition of PYRAMID, this would mean that a robot could be contacting the floor, level 1, and level 2 and the same time. However, when I downloaded the manual today after I noticed an irregularity in the Q&A, I found the following:
"A ROBOT has CLIMBED its PYRAMID if it contacts the PYRAMID and/or the floor (Level 0) in A. sequential order (Level 0, 1, 2, 3) during ascent and B. no more than two (2) Levels simultaneously."
This is the only difference I've seen, but I bet there's more. Just a heads up to everyone, you may want to re-download the rules.
Tucker Gordon
Team 1540: The Flaming Chickens
Co-Captain
Drive Coach
Manager: Competitive Analysis
Co-Manager: Mechanical Engineering
Unread 10-01-2013, 00:08
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is online now
Coach
FRC #1086 (Blue Cheese)
If this is true, then a robot this is over 30" tall could not legally climb the Pyramid. IS this the intent of the rule?
Domtech's Avatar
Domtech Domtech is offline
I Do Everything
AKA: Dominic
FRC #2412 (Robototes)
Domtech is an unknown quantity at this point
Um, that was actually announced in the first team update.
Unread 10-01-2013, 00:11
Domtech's Avatar
I Do Everything
AKA: Dominic
Over 30 inches is fine, as long as you don't CONTACT it in more than 2 zones.
Unread 10-01-2013, 00:12
wilsonmw04's Avatar
Coach
Is was just going to post this:
The requirements in Section 3.1.5.2 A and B pertain to the ROBOT'S contact with the PYRAMID and/or floor within each Level, not the ROBOT'S presence in the physical space of the Level.
this makes life MUCH easier
Unread 10-01-2013, 00:18
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
Alright I thinking know what you mean but would you care to clarify?
"Sometimes the questions are
complicated but the answers are simple."
- Dr. Seuss
FRC #2443
Where did you see that post? I am just wondering?
Unread 10-01-2013, 00:27
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
I think this might help. So your grabbing the level 1 bar, still touching the floor, but your robot is more than 30 inches high so it extends into the airspace of level 2. But since your are not in contact with level 2 bar, you are only consider in two levels. The airspace between the bars does not count to the "what levels your in".
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 10-01-2013, 00:38
nitneylion452's Avatar
AKA: Joe Lee
Well, not quite. Being in a level's airspace is ok. It's touching the pyramid in more than 2 zones that isn't. For example, touching the floor (level 0), the bar in level 1, and the bar in level 2. Simply touching the floor and the bar in level 1 is ok, even if your robot is occupying some of level 2's airspace. The robot just can't touch the pyramid in more than 2 zones at once.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 10-01-2013, 00:39
AKA: Garty
Yes it does! Thank you!
- Dr. Seuss
Unread 10-01-2013, 07:07
wilsonmw04's Avatar
Coach
this is what I was concerned about. The clarification takes it off the table.
Unread 10-01-2013, 12:05
joshjet joshjet is offline
FRC #4344
joshjet is an unknown quantity at this point
I'm sorry, but I guess I still don't understand completely. Does this mean that we would be unable to reach directly to the second bar while sitting on the ground?
