Go to Post I'm absolutely certain that kids prefer scoring points to not scoring points - AdamHeard [more]
Unread 05-01-2013, 11:26
Wsen Wsen is offline
FRC #0057
Wsen is an unknown quantity at this point
Arduino and Motors
Is there a way to control six ftc tetrix motors with one arduino and motorshield.
Unread 05-01-2013, 17:51
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Re: Arduino and Motors
R54
Custom circuits shall not directly alter the power pathways between the ROBOT battery, PD Board, motor controllers, relays, motors, or other elements of the ROBOT control system (including the power pathways to other sensors or circuits).
Unread 10-01-2013, 08:36
Wsen,
You may be able to use the Arduino to control FTC type motors using the HiTechnic motor controllers. However, this product in intended to use the NXT to address the motors. If you can interface the Arduino to emulate an NXT controller then it should work just fine.
Unread 10-01-2013, 10:07
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
Originally Posted by DominickC View Post
R54
I do not believe the OP was planning on using this on an FRC Robot.
However make sure that you look at the datasheet for any motor controller sheild that you plan on using and ensure that it has the ability to provide the necessary current, there are a lot of cheap motor controllers on the Open Source market, so you just have to be a smart consumer.
Here is the datasheet for the Tetrix motor to get motor specs: https://c10645061.ssl.cf2.rackcdn.co...motorspecs.pdf
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
