Re: pic: The Cow that Jumped over the moon!
The following actions are prohibited with regards to interaction with FIELD elements: grabbing, grasping grappling attaching to, damaging, becoming entangled Actions A-D do not apply to ROBOT interactions with the PYRAMID. |
Oh! I didn't realize the sheet was vertical. In that case, there isn't a design flaw so long as the plate is cut to allow air flow. There's a strategy flaw with point # 5 though:
It would be safe as long as they put some sort of shroud over the blades.
The safety issue isn't in the spinning propellors. The safety issue is the vertical sheet (shown as cow print in their CAD picture) preventing the opposing drivers from controlling their robot -- as called out in the blue box beneath R08. I emboldened the appropriate wording above.
That vertical sheet could be made out of a mesh or something instead. It would still serve the purpose of blocking shots, but not interfere with vision. On another note: Do you think that the FRC battery will be able to provide enough power to keep the robot flying at acceptable altitudes? If you've ever flown one of those remote control helicopters, you'll notice that as the battery gets drained the helicopter's maximum altitude dramatically falls, and as the battery gets even lower you can no longer gain altitude. But I think it would be awesome to see a flying FRC robot! |
I am more interested in which motors you will use for the propellers
#7
Do the power calculations required to fly and/or hover the minimum required equipment in a robot given the available motors and battery. It will soon become obvious why there has never been a flying FRC robot before.
#8
This idea is legal. The lower hanging "shield" that is in a crazy cow print would not be needed. If you have flown or been on a helicopter, you need the open bottom or the robot to get air flow. With the open bottom, the prop wash would create a disturbance and affect the flying ability of all frisbee's that fly underneath it, providing great "D".
This being said, it ruins the spirit of the game. Using the battery and CIM motor's, it is possible to lift that much weight with a helicopter style blade |
#9
I used the calculation method from this website assuming that each CIM is just under 1/2hp and weight roughly 3 lbs. You could use all 6 cims or just 1. The math is complicated, but it walks your through pretty well. You certainly would not have a lot of weight room left but it is possible from my calculations.
http://www.heli-chair.com/aerodynamics_101.html Still, not in the spirit of the game |
#11
Cause I can't imagine this happening but I would love to be suprised |
#12
Yes. Light light light everything. How bout some carbon fiber!!! The battery is the biggest weight. The rest of the electronics are fairly light compared. Build the frame small and start with the props vertical so you do not need much in the way of metal/carbon fiber or bumpers. This is all conceptual, not anything you can or should try. It would get shut down for ruining the spirit of the game as well as safety (carbon fiber explodes).
#13
Exactly. The bumpers, chassis, cRIO, wireless router, PD block, and all the wires will be weight prohibitive. Even if you got the robot flying, you wouldn't have enough weight left to make any sort of manipulator.
#14
Using the method from that website:
Area = #rotors * diameter^2 * pi/4 Area = 4 * 14in^2 * pi/4 = 616 in^2 = 4.28 ft^2 Power will be limited by the battery and main breaker, with a maximum continuous power of: Power = voltage* current = 12 V * 120 A = 1440 W = 1.93 HP PL = Power/Area = .452 HP/ft^2 TL = 8.6859 * PL^(-.3107) = 11.12 lb/HP Thrust = Power * TL = 11.12 lb/HP * 1.93 HP = 21.5 lb The battery alone is 12 lb. Each CIM is 2.8 lb. If I did the math correctly, I don't think you can fly. |
#15
