Go to Post IMHO if it was legal a peg leg would be better than a caster. - Edoc'sil [more]
Unread 10-01-2013, 10:18
Re: Best motor/gearing option to drive a shooter?
Originally Posted by Djur View Post
5200 rpm CIM geared at 1.5:1 => 7800 rpm. He rounded that up.
Who said they are running it at full voltage ?
Unread 10-01-2013, 10:46
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Before we can answer the question of the best motor/gearing option, we need to determine the ideal exit speed.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 10-01-2013, 11:00
Does anyone have any data (actual measurements) for the following?
1) what effect do different shooter wheel speeds have on frisbee flight path (e.g. height at the target distance) ?
2) how much does your shooter wheel slow down when a frisbee passes through it ?
Unread 10-01-2013, 12:30
Aren Siekmeier's Avatar
on walkabout
Your best bet to determine any of this is to put together something with a launch speed in the desired ballpark and test the desired shot. Then you don't need any math beyond knowing how things scale. We have run all of our tests off of a UPS (uninterruptible power supply) so that we can adjust the voltage to get the desired launch speed. Knowing this speed makes it much easier to design the final mechanism, and we haven't needed any frisbee flight models, only repeated testing.
Of course, we are not simulating any shooter spin down with a UPS, but as already mentioned, leaving headroom for speed control should take care of this.
Unread 10-01-2013, 12:37
Did you gather any data (that you'd be willing to share) during this testing?
Unread 10-01-2013, 12:42
on walkabout
Not that I have access to at the moment. When I get into the shop this afternoon I'll see what I can dig up.
Unread 10-01-2013, 12:55
This post has some useful qualitative observations:
http://www.chiefdelphi.com/forums/sh...2&postcount=55
Unread 12-01-2013, 19:37
smclean1969 smclean1969 is offline
FRC #3512
smclean1969 is an unknown quantity at this point
Something for the 8000 rpm, that's assuming free spin, which isn't accurate for a motor under load conditions. The CIM has to turn the wheel, so it's going to be something less than 8000. It won't be an amazing drop but 7000 - 7500 is probably more reasonable.
Scott McLean
FIRST Team 3512, the Spartatroniks
Team role: mentor
2011: Highest Rookie Seed and Rookie Inspiration Award Long Beach Competition
2012: Winner Los Angeles Regional -- w/ Team 987 and Team 1717
2013: Finalist Los Angeles Regional -- w/ Team 599 and Team 981; Engineering Excellence
2015: Entrepreneurship Award - Ventura Regional
Unread 12-01-2013, 19:40
Could be a lot less than that if the wheel is generating vibration and windage.
Hint: measure the CIM current with a clamp-on ammeter. Then estimate the CIM speed from the voltage and current, as shown here.
Unread 13-01-2013, 18:11
Anybody planning to buy 8" pneumatic and run it at 8000 rpm read this thread:
http://www.chiefdelphi.com/forums/sh...d.php?t=111118
Unread 14-01-2013, 05:44
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
Is there anyone considering using dual banebot 550's to drive their shooter?
Unread 14-01-2013, 09:41
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Yes.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 10-01-2013, 13:02
neshera's Avatar
neshera neshera is offline
Nesher G. Asner
AKA: Nesher G. Asner
FRC #1625 (Winnovation)
Team Role: Parent
neshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud ofneshera has much to be proud of
FWIW, World's record for fastest frisbee throw was 74 mph in 1988 (citation: YouTube video from Guiness Book of Worlds' Records TV show)
Do not panic! All is well!
- Kevin Bacon in Animal House
Unread 10-01-2013, 13:17
on walkabout
Note that with any no-slip one-sided design, the tip will have to be going twice as fast as the desired exit velocity, since half of the imparted velocity must go into spin. So even if we only need a 70mph launch, the shooter would need to be going 140mph.
Add in a second side, however, and that changes entirely...
Unread 10-01-2013, 13:20
http://www.chiefdelphi.com/forums/sh...8&postcount=36
