#16
Re: pic: The Cow that Jumped over the moon!
This idea is legal. The lower hanging "shield" that is in a crazy cow print would not be needed. If you have flown or been on a helicopter, you need the open bottom or the robot to get air flow. With the open bottom, the prop wash would create a disturbance and affect the flying ability of all frisbee's that fly underneath it, providing great "D".
This being said, it ruins the spirit of the game. Using the battery and CIM motor's, it is possible to lift that much weight with a helicopter style blade |
#17
I used the calculation method from this website assuming that each CIM is just under 1/2hp and weight roughly 3 lbs. You could use all 6 cims or just 1. The math is complicated, but it walks your through pretty well. You certainly would not have a lot of weight room left but it is possible from my calculations.
http://www.heli-chair.com/aerodynamics_101.html Still, not in the spirit of the game |
#19
Cause I can't imagine this happening but I would love to be suprised |
#20
Yes. Light light light everything. How bout some carbon fiber!!! The battery is the biggest weight. The rest of the electronics are fairly light compared. Build the frame small and start with the props vertical so you do not need much in the way of metal/carbon fiber or bumpers. This is all conceptual, not anything you can or should try. It would get shut down for ruining the spirit of the game as well as safety (carbon fiber explodes).
#21
Also, what happens if you're not hanging onto the tower at the end of the match and your power gets cut? I'm guessing it wouldn't be well-liked to watch a 100 lb robot falling 10 ft to the ground ![]() |
#22
Exactly. The bumpers, chassis, cRIO, wireless router, PD block, and all the wires will be weight prohibitive. Even if you got the robot flying, you wouldn't have enough weight left to make any sort of manipulator.
#23
That being said, if you run 6 CIMs at full power continuous a) your battery will probably drop to at least half-voltage within a minute and b) the motors will likely overheat and start losing power. All of this ignores the safety aspect, which is that FIRST probably wouldn't allow a flying robot onto their field on safety grounds. The nets are designed to contain frisbees, not runaway helicopter bots. |
#24
6 CIM's all working near full power? You'd trip the main 120A breaker in a few seconds.
#25
While they wouldn't be at free current, they wouldn't be drawing massive amounts of current if they are powering a light-weight rotor, would they? |
#26
The point of this conversation being... Someday it will be possible. Try it outside of the competition for fun!!!
#27
Using the method from that website:
Area = #rotors * diameter^2 * pi/4 Area = 4 * 14in^2 * pi/4 = 616 in^2 = 4.28 ft^2 Power will be limited by the battery and main breaker, with a maximum continuous power of: Power = voltage* current = 12 V * 120 A = 1440 W = 1.93 HP PL = Power/Area = .452 HP/ft^2 TL = 8.6859 * PL^(-.3107) = 11.12 lb/HP Thrust = Power * TL = 11.12 lb/HP * 1.93 HP = 21.5 lb The battery alone is 12 lb. Each CIM is 2.8 lb. If I did the math correctly, I don't think you can fly. |
#28
I am fairly sure this is illegal because you blocking the sight of a drivers station and it is not safe at all. plus with disks flying and hitting the wall you better hope that is a stable system or everyone would get to see a cliche ladder tipping scene.
