Go to Post This tee-shirt collecting gets kind of addicting, doesn't it? - Chief Hedgehog [more]
Go Back   Chief Delphi > Technical > CAD
Unread 09-01-2013, 19:39
Gaiice Gaiice is offline
AKA: Caius
FRC #4743
Gaiice is an unknown quantity at this point
2013 SolidWorks KOP
We were wondering if anyone has the 2013 KOP as Solidworks files, if so can you share. We do not have any other cad systems other than SW.
Thanks!
Unread 09-01-2013, 19:42
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: 2013 SolidWorks KOP
See the Autodesk Student community page on the Autodesk page. SW will read STEP files without a problem.
http://www.chiefdelphi.com/forums/sh...d.php?t=110483
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 09-01-2013, 19:47
AKA: Caius
FRC #4743
We are aware of this, however we are also having difficulty accessing this site, which is the issue.
Unread 09-01-2013, 19:55
AKA: Nathan Hui
PM inventor_phild. He should be able to help you.
There may be a zipped file with all of that stuff somewhere on CD. I think I saw it. When or if I find it, i'll link it here.
Nathan Hui
FTC 4950, 6038
Unread 09-01-2013, 19:58
AKA: Nathan Hui
See if http://students.autodesk.com/ama//or...EP-Format1.zip works.
Nathan Hui
FTC 4950, 6038
Unread 10-01-2013, 12:22
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Thanks to Nathan for helping with this.
Gaiice, if you are still having issues, email me privately and I will help you.
phil.dollan@autodesk.com
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 11-01-2013, 12:22
Sk8sonh2o Sk8sonh2o is offline
FRC #4055
Sk8sonh2o is an unknown quantity at this point
Thanks Nathan!
Is there a translator available for using 3-D PDF's as a common language between Inventor, SW (& Creo?)
Tom G 4055
Unread 13-01-2013, 21:08
Typically formats such as 3D PDF or 3D DWF are output from an application such as Inventor for use by someone in the design team who wants to mark up or view the design. The PDF or DWF has most of the 3D data stripped out. It may be useful for cheking but in general it does not work as you are requesting.
I will check further and let you know if I can find any more information. Email me privately if you do not hear from me in a couple of days.
Phil Dollan
Autodesk Inc.
