Go to Post You lame pig farmer! I'm not talking about a bunch of dudes sitting around eating their packed lunches that Mommy made. - Paul Copioli [more]
Unread 10-01-2013, 15:17
SoyStuff SoyStuff is offline
FRC #1257
SoyStuff is a jewel in the roughSoyStuff is a jewel in the roughSoyStuff is a jewel in the rough
Getting the Axis Camera Working
Hello. We are trying to get the Axis Camera working. We have followed the instructions in this document: http://wpilib.screenstepslive.com/s/...an-axis-camera.
However, in spite of our best efforts, we have been unsuccessful in making the camera work. We can see it when we visit its IP address in a browser, but it doesn't want to talk to the DriverStation when plugged into the CRIO. We are using the Axis Camera setup tool. We installed the latest software, but it says it is v. 2012.1.18. Is this the correct version? Do you have any idea what is wrong? If you got it working, what did YOU do?
Unread 10-01-2013, 15:41
Re: Getting the Axis Camera Working
Did you run the camera configuration? It updates the camera to have an account called FRC with a password of FRC so that it will serve images to the driver station application. You can also do the setup using the web browser.
Greg McKaskle
Unread 10-01-2013, 15:50
FRC #1257
We did that.
Unread 10-01-2013, 15:53
ttshaw1 ttshaw1 is offline
FRC #1257
ttshaw1 is an unknown quantity at this point
Bump. Was wondering the same thing myself.
Unread 10-01-2013, 16:35
The default dashboard is built to connect to the camera through the Radio, not the cRIO.
Unread 10-01-2013, 16:41
FRC #1257
How do we make it work through the CRIO? Thanks.
Unread 10-01-2013, 18:33
Why do you want to plug it into the cRIO? Note that the default cRIO code is also set up to work with the camera connected to the bridge.
I highly recommend configuring the camera with the tool using the robot radio option, then hooking the camera up there. It is much easier.
It also looks like the new Dashboard won't show the camera feed unless the DS is running and connected to the cRIO.
