Go to Post Nothing you learn can truly prepare you for everything that comes your way. - sciguy125 [more]
Unread 10-01-2013, 18:53
Re: Jaguar problem
Are both limit switch jumpers in place on the jaguar with the issue? They are located on the right side of the set of ports on the front of the controller. Compare the two controllers if you're unsure.
This was a common failure mode of the grey jaguars but based on your team number I'd have to imagine you're referring to a black jag
