Go to Post Texas! Here we come! - Harrison [more]
Unread 10-01-2013, 19:00
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Re: Entering goal
Someone please correct me if I'm wrong, but if the field includes the low goal and the low goal includes the chains, then the chains are in the field of play and can be touched without penalty. Looking at that logical chain, the only part of which I'm unsure is that the chains are part of the goal.
2.2.3: Each ALLIANCE’S LOW GOAL is located adjacent to the opponent ALLIANCE WALL and to the opponent DRIVERS’ left. The opening of the LOW GOAL is 29 in. wide and 24 in. tall. The bottom edge of the LOW GOAL is located 19 in. from the playing surface of the FIELD.
A DISC is considered SCORED in an ALLIANCE’S GOAL if any part of the DISC has crossed through the opening of the GOAL, is in the GOAL at the end of the MATCH, and is not in contact with any ROBOT from that ALLIANCE.
GOAL: a FIELD element in which DISCS are SCORED to earn points for an ALLIANCE.
LOW GOAL: the GOAL located between a FEEDER STATION and ALLIANCE WALL.
Emphases mine. If DISCS are scored in the GOALS, then the GOAL has an inside, which I believe can be assumed to include the chains. The idea that the GOALS have an opening that is parallel to the field wall suggests that this boundary is only the beginning of the GOAL and that there is more goal past that boundary.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 10-01-2013, 19:11
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Entering goal
The low goal is defined as part of the field, due to what Gary Voshol stated.
If this definition of low goal IS true, and follows over to high goals, then touching the chains should be legal, assuming the robot does not get entangled.
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 10-01-2013, 22:31
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Entering goal
It's certainly worthy of a Q&A: "Are the chains part of the goal and on the field, or are they outside the field?" I'd be happy to be proven wrong.
(since 2004)
Unread 10-01-2013, 22:37
danopia's Avatar
danopia danopia is offline
Logical Awesome
AKA: Daniel Lamando
danopia is an unknown quantity at this point
Send a message via AIM to danopia Send a message via MSN to danopia Send a message via Yahoo to danopia
Re: Entering goal
Just going off instinct, I'd have to say that the field ends at the field's walls, as that's how the playing area is measured; the chains are beyond this wall, so they're probably going to be outside of the field. Just an assumption, though.
Unread 10-01-2013, 22:42
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: Entering goal
The middle and high goals are both located above the 84" height limit, so no legal robot would be able to enter our touch the chains inside them regardless.
Unread 10-01-2013, 22:57
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Entering goal
Why would you want to go in instead of dropping the discs in from just outside?
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
