Go to Post Earlier today, I finally saw a copy of the [WFA] essay that was submitted by my team (there will be a separate reckoning later with all those that kept this a secret from me). The narrative overwhelmed me. - dlavery [more]
Unread 10-01-2013, 19:13
AnimeOtakuStar's Avatar
AnimeOtakuStar AnimeOtakuStar is offline
MOE 365: Supernatural Hunter
AKA: Nina Larock
FRC #0365 (Miracle Workers/MOE)
Team Role: Student
AnimeOtakuStar will become famous soon enough
Disc Lauching Velocity
We're looking to find the exiting velocity of a disc from a launcher. Please provide the basis for your calculation. Thanks~!
From MOE 365
Robotics:
"That's how dad did it, that's how America does it, and it's worked out pretty well so far." -Tony Stark
"Recruiting Students, Building Things, the Family Business."
DON'T PANIC
Unread 10-01-2013, 19:24
JakeD's Avatar
JakeD JakeD is offline
FRC #0360 (The Revolution)
JakeD will become famous soon enoughJakeD will become famous soon enough
Re: Disc Lauching Velocity
Its a dynamics problem but the calculations can change based on how your device is set up. A description of your shooter should be enough to figure out the equations and what variables you'll need to plug in though.
Unread 10-01-2013, 19:34
Mr MOE's Avatar Woodie Flowers Award
Mr MOE Mr MOE is offline
MOE 365 Team Coordinator
AKA: John Larock
None #0365 (Miracle Workerz)
Mr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond reputeMr MOE has a reputation beyond repute
Re: Disc Launching Velocity
Agree. We were wondering if anyone actually measured the velocity of their discs when they exited the shooter/launcher. If so, what did you record and what were the shooter parameters that resulted in that specific velocity (if you are willing to share)?
Thanks.
MOE Celebrates 18 Years in FIRST this season!
2007 CMP Chairmans Award - thanks to all MOEboteers, past and present!
Unread 11-01-2013, 12:08
scaryone's Avatar
scaryone scaryone is offline
FRC #0058 (The Riot Crew)
scaryone will become famous soon enough
Measuring B velocity and wheel RPM this weekend. Will post results
Unread 11-01-2013, 13:10
Thanks.
^This^
It would be a service to the CD community.
Unread 11-01-2013, 15:08
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Here is a neat device that can help you out with your velocity numbers.
http://www.bhphotovideo.com/bnh/cont...G&A=details&Q=
I good video analysis program is UberSense on a Ipad or Iphone
http://www.ubersense.com/
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 11-01-2013, 15:47
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
From MOE 365
I am going to choose to answer a different question. When working on target velocities, we timed how long it took to throw the discs various distances effectively. At what speeds did the discs have ample drop (loosing altitude) and at what threshold dip the trajector appear relatively flat. We chose to do this over a 50' distance as this would be the theoretical super shot, just to see what sort of velocities were required.
This does not give you the "muzzle" velocity, but it does give you the average velocity, and you know you should probably target faster than that at the muzzle.
If you simultaneously take times at teh 25' mark, then you will have the average velocity for that distance as well, and you can use the 3 points to see the trend for speed (total time give total average velocty, timing at 25' mark allows for 25' average as well as the 25-50 foot average by subtracting the two.
Unread 11-01-2013, 16:14
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I have an Arduino Sketch that you are free to use to create a Chronometer. All you need is a couple of sensors to attach that can sense when the disk passes. You may have to change the Interrupt type from "RISING" to "FALLING" depending on the sensors you use.
Just edit the distance value in the code to match the separation distance between the sensors and it will spit out the velocity in ft/sec whenever the two sensors are triggered by a passing object.
* This Sketch is for a Chronometer that uses the "micros" function to capture two points in*
* time and determines how much time has elapsed between them in microseconds. By knowing    *
* the distance between the to sensors, the velocity of the object can be determined.       *
* Bill Kendall, Jan. 11, 2013                                                              *
#define SENSOR_DIST 6  //This value is the distance between the sensors in inches
unsigned long event1 = 0; // value in 'micros" at the time of this first trigger
unsigned long event2 = 0; // value in 'micros" at the time of this second trigger
int calculate = 0;  // If set to 1, a calculation and display of the velocity will occur
unsigned long duration = 0; // Amount of elapsed time between events
unsigned long velocity = 0;
void setup (void)
attachInterrupt (0, ISR0, RISING);  // Interupt 0 (pin 2) calls "ISR0" Thie is the first trigger
attachInterrupt (1, ISR1, RISING);  // Interupt 1 (pin 3) calls "ISR1" This is the second trigger
Serial.begin(115200); // connect to the serial port
void ISR0 (void)
  event1 = micros(); // record the microseconds counter
void ISR1 (void)
  event2 = micros(); // record the microseconds counter
  calculate = 1;  // Allow the velocity calculation code to run.
void loop (void)
  if (calculate != 0);
    RunMath ();
void RunMath (void)
  duration = (event2 - event1); // elapsed time between triggers in u seconds
  velocity = ((SENSOR_DIST/duration)/12)*1000000;  // Calculate velocity in feet per second
  Serial.print("The projectile is moving at ");
  Serial.print(velocity);
  Serial.println(" ft./sec.");
  calculate = 0;
Unread 11-01-2013, 21:11
DonRotolo's Avatar
Back to humble
FRC #0832
Can you share some of your findings? I'd really be interested in knowing what a good range of 'times' for the 25 foot distance is, for a fairly flat trajectory.
Unread 11-01-2013, 23:47
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
I built a limit-switch triggered arduino timer tonight, I'll do some testing with the team tomorrow and report my results here. We will be shooting at a fridge around 24' 9" away using two different types of wheels. The first an 8" AM Pneumatic wheel and the second an 8" plaction wheel.
You can see a video of our shooter here; http://www.youtube.com/watch?v=ThZCOtjVJmw
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 14-01-2013, 13:02
billbo911's Avatar
I've "refined" my Chronometer sketch (read that as "I now have it working correctly"). After testing it, I found it wasn't quite what I wanted, so I fixed it.
Please enjoy!
float SENSOR_DIST = 6;  //This value is the distance between the sensors in inches
float distance;
int firstint = 0;  //Set to 1 if Interrupt 0 has occurred
float velocity = 0;
void setup (void)
attachInterrupt (0, ISR0, FALLING);  // Interupt 0 (pin 2) calls "ISR0" Thie is the first trigger
attachInterrupt (1, ISR1, FALLING);  // Interupt 1 (pin 3) calls "ISR1" This is the second trigger
distance = (SENSOR_DIST/12.0); // Convert sensor spacing to feet
void ISR0 (void)
  firstint = 1;
void ISR1 (void)
  calculate = 1;
void loop (void)
  if (calculate == 1 && firstint == 1)
    RunMath ();
  delay (500);
void RunMath (void)
  velocity = (((distance)*1000000)/(duration));  // Calculate velocity in feet per second
  Serial.print (velocity,2);
  calculate = 0;
  firstint = 0;
Unread 14-01-2013, 13:35
Aren Siekmeier's Avatar
on walkabout
With our latest shooter setup, we measured frisbee exit velocity very roughly with a 60fps camera as well as launch surface speed (under no load) with an optical tachometer. When making 3pters from 30" directly above the auto line, we measured an exit speed of roughly 2400 ft/min (+/- a few hundred), with the launch surface going about 6000 ft/min under no load (one-sided with no noticable slip, so you can see there is some spin down in our implementation, but it spun back up within a second). These numbers are lower than we had previously been estimating, but hey that's why we test.
Unread 14-01-2013, 13:55
Would you please describe your latest shooter setup, to give some context to the numbers you posted.
How do you know it was 6000 ft/min, i.e., how did you measure that?
Unread 14-01-2013, 14:16
cseabury cseabury is offline
FRC #2272
cseabury is an unknown quantity at this point
There is a nice software package for the I phone. "Vernier Physics."
Take a video of the frisbee launching past some landmarks of known separation, mark those spots, and you can get the time in between.
Unread 14-01-2013, 14:44
on walkabout
We powered a 360mm circumference pulley off of a CIM at 12V, and measured about 5200rpm under no load (the tach actually pegged out, so we measured at 3V, 6V, and 9V and extrapolated). This gives a tangential velocity of 360mm*5200rpm/25.4/12=6100 ft/min.
We had about 12in of contact with the belt.
To measure exit velocity, we took several 60fps videos of the launch, and measured a 4ft travel out of the shooter in 6 or 7 frames, averaging about 2400 ft/min. The low frame count of course makes the uncertainty on this figure substantial (about 300ft/min per measurement, 100ft/min over 10 measurements).
