Go to Post They are "Human Dream and Inspiration Enablement Devices" but since that takes too long to say and explain I use the word "robot". - Foster [more]
Unread 10-01-2013, 19:43
xraymypanda's Avatar
xraymypanda xraymypanda is offline
Cowboy programmer
AKA: Chris M
FRC #0599 (RoboDox)
xraymypanda has a spectacular aura aboutxraymypanda has a spectacular aura about
Using two cameras without exceeding bandwidth limits?
Does anyone know how we would be able to use two cameras without exceeding the 7Mb/s limit? Last year we used two cameras on our robot but ended up removing one of the cameras because we were managing to use way too much bandwidth at the time when there was no limit. Now we are stumped but we would love to have one camera on our disc intake and another on our shooter. I've considered having a switch that changes which camera is initialized at a time but worry that this will cause the camera to have to reboot every time we switch?
2011: Head Scout
2012: (figure)Head Programmer
2013: Head Programmer, Chief Strategist, Outreach Executive, and Driver
Unread 10-01-2013, 21:01
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Using two cameras without exceeding bandwidth limits?
Turn the compression setting way up (60+).
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 11-01-2013, 07:58
It also helps to turn the resolution down. Ignoring compressions, a 640x480 image has about 310 thousand pixels, a 320x240 has 1/4th as many, and a 160x120 has 1/16th as many. Compression impacts it as well. The default dashboard will tell you an approximate bandwidth used by the camera. If you add a second camera using a LV dashboard, just add the two numbers together before displaying.
Greg McKaskle
Unread 11-01-2013, 11:49
I think your problem last year may have been exceeding the processing power of the classmate with two cameras, rather then overruning the field bandwidth. This year, the charts tab on the driver station shows the Driver Station CPU %, which will make it easier to track down those kind of issues.
Unread 12-01-2013, 13:03
Cowboy programmer
AKA: Chris M
FRC #0599 (RoboDox)
Thanks for the suggestions, we will be sure to try them out. We shouldn't have had a problem with CPU because we opted for a more powerful netbook last year in place of the Classmate.
2011: Head Scout
Unread 12-01-2013, 15:46
Sorry, I might have been thinking about a previous year.
Unread 12-01-2013, 20:34
yash101 yash101 is offline
AKA: null
Just reduce the settings. To do it, log onto your camera's web interface. Go into settings and change the resolution/quality/compression. For you, you might want to reduce the frame rate, and reduce the resolution a bit. put the compression level at 40-50. That will give a good enough quality to be usable.
Unread 12-01-2013, 21:29
splatter's Avatar
splatter splatter is offline
Cant Spell Robots With Out Rob
AKA: Robert
FRC #0271 (Mechanical Marauders)
Team Role: CAD
splatter will become famous soon enough
1) Increase the Compression
2) Decrease resolution
3) Decrease Frames Per Second
Hope that helps!
FIRST Team 271
<Electrical, CAD>
http://www2.bayshoreschools.org/robotics/
Unread 12-01-2013, 22:31
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Frames per second is probably the first thing you should try reducing, with compression set to 30 to start with. Find the lowest fps value that is still useful to your drivers. Computer vision isn't likely to require more than 4-8 fps. Then reduce the resolution to the lowest value that still works for you, and then if you're still close to the limit increase compression.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
