Go to Post Super Regional? I don't know...if you combine NJ and Philly the universe might tear a hole in itself...and we wouldn't want that now would we? Mwahaha. - George A. [more]
Unread 10-01-2013, 21:19
timothyb89 timothyb89 is offline
code monkey
FRC #1977 (Loveland High Robotics)
timothyb89 will become famous soon enough
Re: Image display to smartDashboard.
Originally Posted by Hypnotoad View Post
So do I have confirmation that I will have to write my own widget.
We did this last year, we modified the SquareTrackerExtension from the smartdashboard svn repository to have it draw polygons recognized by our vision code: source
The usual image processing additions are in processImage() (which did the bounding boxes) and then the UI additions are in paintComponent(). The additions were mainly some debug text and the ability to click and select polygons for the targeting system.
I'm a bit unfamiliar with the the 2013 vision code, but if it's at all similar this could help out a bit.
FRC-DB: A detailed, web-based scouting database for FRC teams with lots of interesting statistics.
Unread 12-01-2013, 10:07
Hypnotoad's Avatar
Hypnotoad Hypnotoad is offline
Junior Assistant Secretary of Moon
Hypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these partsHypnotoad is infamous around these parts
I started a new thread about this but I'm going to ask it here as I have not gotten any replies on said thread. Does anyone have GOOD documentation on how network tables works? The java docs don't count. I mean like a PDF.
The following sentence is true.
The preceding sentence is false.
This sentence is false.
This signature is false.
My teeth are false.
