Go to Post ... the real mark of integrity is doing the right thing even when nobody is watching. - DonRotolo [more]
Unread 10-01-2013, 14:55
crollison crollison is offline
AKA: Chris Rollison
FRC #4809 (Black Knight Robotics)
crollison is an unknown quantity at this point
Cypress System on a chip
Not sure what we will use this for, but trying to follow directions for getting the PSoC image file loaded on the board and when I get to the point where I load the .hex file from the classmate, it tell s me that it is the wrong version "the hex file was built for silicon revision ES3, but the aquired version is revision **.
The hex file that I have on the classmate is FRC_IO.2012.v3.hex, the instructions call for FRC_IO.v3.hex or FRC_IO.v3.2010.hex (or latest version) file.
Any ideas. Thanks.
Unread 10-01-2013, 21:32
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
Re: Cypress System on a chip
The .hex file to use, depends on when your Team received the PSOC-3.
The FRC_IO.v3.hex file should be used if your team received it's PSOC-3 prior to 2010.
The FRC_IO.v3.2010.hex should be used if your team received it's PSOC-3 in 2010 or 2011
The FRC_IO.2012.v3.hex should be used if your team received it's PSOC-3 last year.
PS..... If you would be so kind as to PM me and so I can have you email me some these as I no longer have the older versions and happen to need it.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
