Go to Post Success to me is a feeling that is associated with achieving something you truly worked hard for; something that you can look at and say "That's my best work." - OneAngryDaisy [more]
Unread 10-01-2013, 02:10
run the trap!!!
Team Role: Human Player
Navigating the Minefield
Many matches will be lost this year because of upside-down discs getting stuck under robots.
After kickoff our members powered up some of our old bots and tried driving them over the discs. We did tests with Ball-Shark ('10) which has 6" wheels and lots of ground clearance and with G-Wrath ('11) which has 4" wheels and only about a 1/2 inch of ground clearance.
In normal driving, G-Wrath pushed the upside-down discs out of the way. When the robot was pushed on-top of the discs (lets say by a defender, or by its own power against a wall) a serious problem occurred. The discs became caught on the wheels and the robot lost traction. The wheels touching the ground continued to propel the robot but the wheels trapped inside the discs spun freely.
Driving over right-side-up discs caused G-Wrath to pitch violently.
Similar problems occurred with Ball-Shark, only that robot was able to drive out of the discs more easily due to its larger wheels.
Anyone else concerned by this? Strategies to overcome it?
I'd hate to see a field of robots spinning in circles helplessly on piles of discs.
-Philip J. Fry
Unread 10-01-2013, 03:02
Undertones's Avatar
Undertones Undertones is offline
Drive Coach
AKA: Mac
FRC #4334 (ATA)
Undertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond reputeUndertones has a reputation beyond repute
Re: Navigating the Minefield
This was a concern of mine. Thank you for testing.
Team 4334, Alberta Tech Alliance, Calgary Alberta
Western Canada 2016 Champions
Western Canada 2016 Creativity Award
Utah 2016 Champions
Utah 2016 Excellence in Engineering Award
Western Canada 2015 Innovation in Control Award
Utah 2015 Champions
Western Canada 2014 Regional Chairman's Award
Western Canada 2014 Champions
Utah 2014 Judge's Award
Western Canada 2013 Champions
Western Canada 2013 Innovation in Control Award
IRI 2012 Champions
Archimedes 2012 Champions - "The Eh Team"
GTR East 2012 Highest-Seeded Rookie
GTR East 2012 Cooperition Award
GTR East 2012 Rookie All-Star
Unread 10-01-2013, 03:19
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
FRC #3309 (Friarbots)
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
It is difficult to speculate without ever seeing a match played, but it seems likely that this will only become a real problem in the last 30 seconds when the supply of discs on the field really starts to grow. However in some matches it could happen much earlier if there are a lot of quick but inaccurate shooters (that said, the concentration of discs should remain around the goals).
Thanks for testing this out - perhaps drivers will need to learn to maneuver around frisbees (blind spot cameras?) rather than assume they can power over them.
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
Unread 10-01-2013, 06:35
GaryVoshol's Avatar
Cogito ergo arbitro
And remember, if you're dragging a couple discs along with you as you move, they count as part of your allowed 4.
(since 2004)
Unread 10-01-2013, 06:52
AndyBare AndyBare is online now
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
I was thinking frisbees flipping wasn't going to be a huge problem per say, because frisbees are giant gyroscopes I think if they hit a wall, they will keep spinning into a wall, then fall. This leads to my second point that of they are upside down, I'm assuming it will be near the scoring walls, because they were attempted to be scored. In this case,... stay away from the wall. Also. I should include, only high upside down frisbee field time would be humans throwing them in, in my opinion, maybe a frisbee hits the 68 degree bar, and it flips over by hitting the Pyramid. So what I'm saying is maybe the frisbee thing isn't a threat at all. I would be prepared for both situations I guess we will only know at scrimmage.
Unread 10-01-2013, 07:22
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Despite all that, you always design to make sure that it won't happen. If it can, it will, and teams that say "it's pretty unlikely" are doomed to have it happen. Many times at the worst possible time, like in the semis or finals of a competition. Top bots take everything into account - especially stuff like this that can wipe out your mobility for a match.
Unread 10-01-2013, 19:14
Yeah, definately agree.
Unread 10-01-2013, 19:28
Finkmeister's Avatar
Finkmeister Finkmeister is offline
Master of Ceremonies
AKA: Seth
FRC #3373 (Team Robohawk)
Team Role: Electrical
Finkmeister is an unknown quantity at this point
This was one of my biggest concerns this year, glad someone went out and tested it.
The obvious option is giving the robot plenty of clearance. Maybe a "snow plow" type thing in the front?
Unread 10-01-2013, 19:54
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder
AKA: noops
FRC #1648 (G3 Robotics)
Team Role: Team Spirit / Cheering
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Perhaps this is a call for a drivetrain with an unbelievably low ground clearance? The only problem I see with that would be the little hump with the pyramid.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
RIT Graduate Student, CompE
Unread 10-01-2013, 22:02
Mongai's Avatar
Mongai Mongai is offline
Indian Guy
AKA: Alec
FRC #0935 (RaileRobotics)
Mongai is just really niceMongai is just really niceMongai is just really niceMongai is just really niceMongai is just really nice
This is precisely the reason why we are using custom tank treads again this year.
Unread 10-01-2013, 22:07
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Well, the great majority of frisbees that are going to be "in the way" are missed shots, which will all be in the front of the goals. And by the time 30 seconds hits, most all teams will be at their pyramids and climbing.
So unless you run though where your missed shots end up I don't really see much of a problem here.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 10-01-2013, 22:13
JB987 JB987 is online now
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Food for thought...there will be "minefields" on both sides of the field, so 2/3rds of field may present a challenge for some teams as they traverse from load in to the other side to score.
"A genius is just a talented person who does his homework" T. Edison
Unread 10-01-2013, 23:13
pfreivald's Avatar
AKA: Patrick Freivald
What about frisbees accidentally/intentionally plowed around the field?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 10-01-2013, 23:21
DonRotolo's Avatar
Back to humble
FRC #0832
more ground clearance?
Unread 10-01-2013, 23:31
camalex3999 camalex3999 is offline
AKA: Cameron Alexander
FRC #3999 (The Shadetree Mechanics)
camalex3999 is an unknown quantity at this point
This was a problem for my team last year. Our robot had six inch wheels and about five inches of ground clearance. Sometimes when we would drive over a ball on accident it would get lodged in between two wheels, which kept us from moving at all. I could see the same happening with a Frisbee that is upside down to a robot with wheels that are close together.
