Go to Post Have no fear, ancient and brilliant coaches of yore were consulted. - JamesCH95 [more]
Unread 11-01-2013, 00:18
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
Netbook as Driver Station
Hey, our team is planning to purchase a netbook to use as our driver station due to the classmate being an E09 and the years of use have deteriorated the battery to the point where it doesn't hold a charge for long. Would installing the DS software that came with labview be sufficient? Also is there inything in the rules that prevents us from doing this? Thanks for any help.
Unread 11-01-2013, 00:25
propionate's Avatar
propionate propionate is offline
Team co-lead and LabVIEW programmer
AKA: Stephen
FRC #1732 (Hilltopper Robotics)
propionate is on a distinguished road
Re: Netbook as Driver Station
I have yet to see anything restricting what types of laptops can be used, but rest assured that a large number of teams use their own laptops for the driver's station. You can simply install the LabVIEW driver's station software on your computer of choice. Some resolution changes may be needed if you want it to fit nicely on the monitor though.
Unread 11-01-2013, 09:11
Timekeeper00 Timekeeper00 is offline
FRC #1391
Timekeeper00 is an unknown quantity at this point
I would be careful buying a netbook as a driver station. The biggest reason would be the lack of processing power, which would be pretty important if you wanted to off-load something like vision processing to the driver station instead of doing it on the cRIO (which is always a good idea). The other reason I would avoid using a netbook would be the lack of screen real estate. If you wanted to put 2 video feeds at a useable size on something with a 10.1" monitor, you would have to use pretty much the entire screen.
As a side note, there is a charger for the Classmate at each driver station, is there not?
-Ti00
Unread 11-01-2013, 09:46
Details from FIRST on how to install the Driver Station on a non-Classmate
Yes, the primary benefit of a Classmate is that chargers are provided for them on the field.
Non-Classmate laptops must run off battery power, so keep your laptop charged in the pits. No we cannot plug them into the field power.
Unread 11-01-2013, 09:50
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
You would need two installer pieces for the DS. From the National Instruments DVD installation you would choose "Install Only Driver Station Support". Then you download and install the Driver Station update from:
http://joule.ni.com/nidu/cds/view/p/id/2263
Doug Norman
Unread 11-01-2013, 19:11
Ohh, ok thanks. We just feel it's time for a new DS
