Go to Post So.... football pizza water game with minibots and megabots? - euhlmann [more]
Unread 19-01-2003, 10:47
Morgoth Morgoth is offline
#0471 (Cybertigers)
Morgoth is an unknown quantity at this point
Whats wrong with this code?
This is my first year doing the programming and I am having trouble with if statements. I know C++, Javascript, regular BASIC but i can't figure out whats wrong with this.
if (p1_y > 135) then skip:
skip:
relay1_fwd = 1
I used "skip:" because if I just put relay1_fwd = 1 under then, it tells me that it expects a label or something directlyafter then. I have tried it with 135 < p1_y and that doesn't work either. I have verified that something is hooked up to relay1, so that isn't the problem. It compiles fine but when I put the y axis on port 1 to greater than 135 nothing happens. I know the joystick works because I have checked it using dashboard.
Also, does white space matter in PBASIC?
Thanks a lot
Unread 19-01-2003, 10:52
#0471 (Cybertigers)
BTW I have tried this in v1.33 and PBASIC 2.5 the same thing seems to be happening in both.
"Lock the Doors"
NASA chief flight director Leroy Cain on the loss of Columbia's signal.
Unread 19-01-2003, 11:07
ChrisA's Avatar
ChrisA ChrisA is offline
#0857 (Superior Roboworks)
ChrisA is on a distinguished road
Send a message via AIM to ChrisA
Relays have 2 variables to control them. So if your other variable (relay1_rev) isnt set to 0 then nothing will happen. If you switch directions elsewhere in the code and you don't change relay1_fwd to 1 there, then you will have both of the 2 relay variables set to 1 which is an error.
Also, the : after skip in the if then statement line is not necessary.
Why don't you try a different word than skip. There are some words that you cannot use for labels. Apparently this is one of them. I'm sure you could go look in the manual and find that skip is a different command. I took your code and loaded it into the editor and changed skip and added a random letter after it and the code tokenized.
If the code does not tokenize then I would not run it on the Robot Controller.
Programmer
Team#857
Superior Roboworks
WildStang Alum
Unread 19-01-2003, 11:09
Ameya's Avatar
Ameya Ameya is offline
Freelance Goon
FRC #0293 (SPIKE Robotics)
Ameya is on a distinguished road
Send a message via ICQ to Ameya Send a message via AIM to Ameya
skip:
relay1_fwd = 1
In PBasic 1.33 and earlier, if-then branching works like this: if the condition is true, then execution continues at the label following "then"; if it is false, then execution continues at the next statement. In your statement, the label "skip:" comes immediately after the if statement, so it is executed in both cases. Here's what it should look like:
relay1_fwd = 0 &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n bsp;&nbsp;&nbsp;&nbsp;'the "else" case
goto endif:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n bsp;'without this, execution would just continue at the next line, "skip"
skip:
relay1_fwd = 1 &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n bsp;&nbsp;&nbsp;&nbsp; 'the "then" case
endif:
Ameya Agaskar
Team 293 alumnus
Unread 19-01-2003, 11:45
#0471 (Cybertigers)
Thankyou a lot!!!! I did a little changing around and I got it working.
"Lock the Doors"
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Autonomous code PBoss Programming 7 14-01-2003 15:29
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
How much code can an IFI controller handle? Larry Barello Programming 7 10-02-2002 19:06
Patent source code? Kyle Fenton Chit-Chat 3 20-10-2001 17:53
