Go to Post Anything that moves sideways is a waste of time. - Tom Bottiglieri [more]
Unread 11-01-2013, 09:54
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Designing a climbing mechanism for 2013... a humbling experience
Originally Posted by danopia View Post
For those of you that have ideas for a 30-point climb, would your robot be able to scale to a pyramid of, say, 10 levels without nontrivial changes? Ignore your robot hanging 30 feet in the air.
It seems like some postings I've seen would because it's repetitive, and others have like a full dance routine going on that lands perfectly on top and wouldn't work for any other pyramid.
Our design is a basic extension of what we did in 2010 - same basic concept, but double the level of complexity to get to the third level. In fact, the level of complexity to go from 2 to 3 is actually less than that required to go from 1 to 2 with this design!
As for adding levels... the changes wouldn't be non-trivial, but they would be direct and obvious. Of course, to go 10 levels we would need a much bigger frame perimeter There's an alternate concept that branched off from this one that would allow us to tackle any number of levels successfully - basically the same design with a few added tweaks that amount to a lot of control complexity. But limiting to 3 levels proved much easier in the design.
2016: Lake Superior WFFA
Unread 11-01-2013, 10:00
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Originally Posted by Siri View Post
Basically this
"Oh baby, dey goin' fo' da hookup!"
Unread 11-01-2013, 10:02
SciBorg Dave SciBorg Dave is offline
AKA: Dave Tharp
FRC #5920 (VIKotics)
SciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to behold
Originally Posted by FrankJ View Post
A fall from zone 3 will pretty much end your robots day. I don't really see the risk/reward as worth it. It will be interesting to see somebodies creative solution to this.
We have an idea but is it worth the weight and possible fall.
We may just do a 10 easy or 20 hard over a 30 very hard and a lot of weight
Unread 11-01-2013, 10:18
pfreivald's Avatar
AKA: Patrick Freivald
That's true for us, too. Once we're at two, going to three should be essentially a repeat of what we just did... (And to answer the question, we should be able to climb an arbitrary number of levels given time and battery life.)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Mentor, LRI, MN RPC
Partly for that reason, and partly for added stability, our design is basically doubled on each level. Grabbing twice instead of one per level should prevent any catastrophic failures!
Unread 11-01-2013, 10:24
Pendulum^-1's Avatar
Pendulum^-1 Pendulum^-1 is offline
AKA: Jim Grove
FRC #1915 (Firebird Robotics)
Pendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nice
We think we have a solution. Of course, I thought that a few days ago, also.
The challenge is significant, the answers will probably be subtle adjustments to a solid concept. The biggest problems are initial docking (we want it to be simple, quick, robust, and tolerant of poor angles of approach), transitioning from level 1 to level 2 (once you have that, 2-3 is rinse and repeat), and getting all the way up to the top of level 3, so that you are totally above level 2.
Rolling off the post and flipping over backwards are certainly problems. CG will be critical in the climb.
And you must really double check all the geometries out.
Is it risky? Yes.
Is the risk worth the reward? We think so.
Jim Grove, Mentor
firebirds1915.blogspot.com
(2007-2017) 1915, McKinley Tech HS, Washington, DC
(2009) 2932, Mid-Pac Institute, Honolulu, HI (Rookie Season)
(2011) 2425, Hillsborough HS, Tampa, FL
(2013-2015) 4464, College Park, MD, 2013 Rookie All Star Winner and 2014 Regional Champions, Washington, DC
FIRST is not rocket science. But it is like drinking from a fire hose.
Unread 11-01-2013, 10:41
Craig Roys's Avatar
Craig Roys Craig Roys is offline
Coach - Team 1718
FRC #1718 (The Fighting Pi)
Craig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond reputeCraig Roys has a reputation beyond repute
Another challenge for some may be the 54" radius. Unless I'm misreading from the Q&A, that is with respect to the floor - so if your robot inverts, it needs to do so inside of a 54" cylinder. They certainly didn't make this a trivial challenge this year.
2016 Waterford District - Semifinalists and Entrepreneurship Award Winner!
2016 Troy District - District Winner and Chairman's Award Winner!
2016 MI State Championship - State Champs with 27, 67, and 6086 and Entrepreneurship Award Winner!
2016 FIRST Championship - Carson Field Quarterfinalists
Unread 11-01-2013, 10:59
Andy A. Andy A. is offline
Getting old
FRC #0095
This was a question posed to the Q&A a couple of times even and, yes, the 54" cylinder is always with respect to the floor, not the robot. If your climbing scheme includes rotating the robot like the video posted earlier in this thread, you'll need to be mindful no part of your robot breaks the cylinder, including bumpers.
One of the more challenging 'size' restrictions we've had.
Unread 11-01-2013, 12:09
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Here is our plan that we are trying to flesh out
https://docs.google.com/file/d/0B44TPv-TccPZTTVWLUV0Z0JlM1U/edit
Hope it works
Faridodin "Fredi" Lajvardi KD7WKD
Unread 11-01-2013, 12:35
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Our concept it somewhat of a "Monkey Bar climbing" approach.
Here is a quick video I threw together yesterday to demonstrate the basic concept to our team. Please excuse the extra enthusiasm I exhibit towards it's potential success, I'm just excited we have something that might work.
http://youtu.be/9kxMmYTVo0E
Unread 11-01-2013, 12:36
DMike
Posts: n/a
How would you rotate/tilt the bottom half of the bot without applying torque to the horizontal pipe. Tilting or rotating the bottom half of the bot on a unfixed upper point would just change the c.o.g and swing it under the bar further. I think ???
Unread 11-01-2013, 12:54
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I think we've found a good solution. I'm especially excited about the possibility of integrating a shooter into the design. Early testing wasn't as awesome as I might have hoped, but I still feel like we have something that will work.
The GDC has done a very good job with this challenge. I've heard some top FIRSTers
saying that only 20 or so teams in the world will be able to hang for 30. At first, I thought that was extreemely pessimistic. Now, I'm not so sure.
-Plutarch
Unread 11-01-2013, 12:59
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
After pounding our head at it a few days, we have 2 designs that we think are within our team's fabrication abilities. I would argue that only one of them is simple but that is an opinion. We're building prototypes of them now and won't know how truly well they work until probably Tuesday next week.
I think "simple" is a relative term for the 30 point climb. A "simple" mechanism for climbing could still have quite a bit of movement.
Unread 11-01-2013, 13:10
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Wwharrgarbl....
I thought we were working toward a doable design for corner climbing, but I was working from the 2011 robot relative right cylinder. Field relative makes things one heck of a lot more difficult for corner climbing. I'm glad we're designing and prototyping shooting mechanisms in tandem. Back to the drawing board and all that...
Player61 Player61 is offline
FRC #3393
Player61 is an unknown quantity at this point
is there a rule for going past the top of the tower with the top end of your robot?
