Go to Post At this rate, Team Update #2 should just eliminate the Minibots and replace it with the drive team captains playing rock-paper-scissors to determine the bonus points. - artdutra04 [more]
Unread 11-01-2013, 11:17
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
Re: 360 Degree, Rotating post launcher
Originally Posted by CalTran View Post
It's basically an Archimedes screw, but going faster in order to shoot, correct? I would definitely prototype something for this, but also keep in mind the sheet size of the end result. Say you use a 2" inner post. That's going to be at least a 2' cylinder, not including outer thickness.
Yup. A theoretical exit velocity of 15 mph at least, if the math holds. A larger post, 45mph, but that requires more space and exceeds the width requirement.
Of course it could be spun faster at a smaller size to take advantage of the additional contact and acceleration time.
Hrmm... interesting thoughts.
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
