Go to Post FIRST is not about a robot competition . . there just happens to be one at every FIRST event. - Stuart [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 18-12-2012, 17:19
iyermihir iyermihir is offline
FRC #0649 (Saratoga MSET)
Team Role: CAD
iyermihir has a spectacular aura aboutiyermihir has a spectacular aura about
Re: Source for Belts and pulleys
Originally Posted by R.C. View Post
So having the ability to make whatever size pulley we want is awesome. I've contacted the FIRST gates rep about models before and they've been happy to send pdf's or coordinates of the belt/pulley profile. I'd love to just find a generator, but no luck so far.
-RC
Is it possible to design a pulley of any size with just the belt profile?
We made some pulleys of weird sizes out of acrylic for the 2012 season that were light and cheap, but it took some tweaking to get it right.
-Mihir
Unread 18-12-2012, 17:33
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
-Mihir
We don't use the belt profile but instead the actual pulley profile.
We use only GT2 5mm x 9mm wide. But you can use other sizes: 2mm/3mm work, 973 used those sizes successfully this year.
-RC
R.C.
MadTown Robotics Team 1323
Unread 18-12-2012, 17:46
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Never though about doing hex like that. Makes a lot of sense. And it saves our team kinda a lot in terms of us, if ever switching to hex (hopefully!) the we wouldn't have to buy a broach machine.
Academic Student (Forever)
Unread 18-12-2012, 18:15
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is online now
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
I've used this method before on other non-FIRST projects that required high precision hex alignment, and it works quite well. The only downside is that you can't go very deep with it on small hex sizes. Typically you don't want to broach very deep anyways, so it's not usually a problem.
That being said, in most cases it's easier to broach. You can hex broach most wheels/hubs for FIRST with just a regular arbor press and some cutting fluid if you're careful, so it tends to require less time than trying to mill it. If you have access to a mill, you most likely have access or room for a press that can broach.
Unread 11-01-2013, 10:36
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
I'm surprised there hasn't been any action on this thread since the game was announced and we got the details on the drive parts in the KoP. Maybe it's in another thread that I've missed, but I've searched and haven't seen it.
The KoP contains two 39-tooth aluminum pulleys, 5mm pitch, 30mm wide. The belts are 15mm wide, so the idea (I presume) is to run two belts side by side on each pulley, going to 15mm width pulleys on separate wheels. Not sure I would have designed it that way, because I don't like the belts rubbing where they cross, but I guess it will work.
The part number given in the Drive Base checklist is P39-5M-30 AL. Searching for "pulley" on AndyMark yields the am-2265, which gives more details such as Gates part number 39-5M25SP01. I can't find either part number, or anything like them, on Gates (or McMaster, or anything else). I've found pulleys (or "sprockets") for 5mm HTD belts, but only in 15mm widths.
We're considering using a different size pulley on the gearbox driveshaft, to change the torque/speed characteristics. For now, we'll try to stay close to the original design of two belts coming off the drive pulley, but we may need to change that. AndyMark doesn't sell any other size, and I can't find it anywhere else.
We don't have the ability to make these parts from scratch. We could combine two smaller pulleys, machining off the flanges where needed (but maybe best to leave at least one flange). How to mount these would be a design consideration, but I think we can figure that out.
Any help on finding sources for these parts would be greatly appreciated. Links are especially helpful.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 11-01-2013, 10:50
pfreivald's Avatar
AKA: Patrick Freivald
http://www.mcmaster.com/ (My favorite site for everything, not always the best for pulleys, though, because they carry mostly steel or plastic)
http://www.bbman.com/products/belts.html (Official Gates distributor)
https://sdp-si.com/eStore/ (Lots of variety especially in timing belt pulleys and belts)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 11-01-2013, 11:27
AKA: Gerry
Thanks, Patrick. I've checked those sites, and still can't find the 30mm wide pulley like the KoP item. If you've found any, can you give me a link to the actual part (or category, part family, etc.)?
Cal
Fairport, NY, USA
Unread 11-01-2013, 12:19
pfreivald's Avatar
Apologies, somehow I missed the 30mm when I read that. Most of those sites carry timing pulley stock, so if you have a lathe you can make pulleys of whatever thickness you'd like.
Team 1551
I write books, too!
Unread 11-01-2013, 12:34
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
You can get the KoP Belts from Andymark: http://www.andymark.com/product-p/am-2451.htm
FRC Team 4334
2012 - Archimedes Champions, IRI Champions
2013 - Western Canadian Regional Winner, Galileo Quarter-Finalilst
Unread 11-01-2013, 12:50
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
And some pulleys I made last night: https://sphotos-b.xx.fbcdn.net/hphot...70581742_n.jpg
GT2 24th 9mm wide. 3 of the holes are tapped for adding a flange.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
