Go to Post I'm about to brain myself on a wall in frustration! - pfreivald [more]
Unread 11-01-2013, 12:46
coollog's Avatar
coollog coollog is offline
Q
AKA: Qingyang Chen
FTC #5485 (PRO)
coollog is an unknown quantity at this point
Re: [FTC]: Set Screws Suck!!!
Also, try to not use set screws whenever possible and keep axles themselves stationary, but the components (wheels and gears) free to rotate on the axle. So, whenever possible, remove axle hubs and add shaft collars.
Qingyang Chen
FTC Team 5485 - PRO, Horseheads, NY
Sponsored by Corning Inc.
Join our fan page: <http://www.facebook.com/ftcpro>
Unread 14-01-2013, 13:07
sandiegodan's Avatar
sandiegodan sandiegodan is offline
FTC Mentor, FRC Inspector
AKA: Dan Glenn
FTC #10092 (Green.Griffins;)
sandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to all
+1 on filing the set screws flat on the tips. Things were much more stable once we did this.
If you are filing manually, put a wrench into the setscrew and hold the two together then rub along a stationary file or flat sandpaper. It's easier to keep the file perpendicular to the set screw. I like using a bare grip as it is easy to judge if you are being too aggressive either with pressure or speed or both by the heat you are generating. It should never be uncomfortable to hold.
Dan Glenn
2015-16 FRC Chairman, San Diego Regional Planning Committee
2016 FRC Inspector, Orange County (LRI), Los Angeles, Carson Division
2015 FRC Inspector, Inland Empire (LRI), Central Valley, Los Angeles, Galileo Division
2015 FTC Mentor 10092 Green.Griffins; R&D Robotics Education
2014 FRC Inspector, Inland Empire, San Diego(LRI), Archimedes Division
2012-15 FTC Mentor Team 6565 Stuffed Dragons & 8489 Green Griffins Boys and Girls Club
2013 FRC Inspector, Central Valley, San Diego(LRI), Los Angeles, Inland Empire, Galileo Division
2012 FRC Inspector, San Diego, Los Angeles, Central Valley, Newton Division
2009-12 FRC Mentor Team 1622 Spyder Poway HS
2007-08 FRC Mentor Team 2658 Pedestrian Rancho Bernardo HS
