Go to Post That's one of the saddest stories I've ever heard. When your green isn't neon enough, you are in big trouble in FIRST. - JaneYoung [more]
Unread 11-01-2013, 14:40
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Re: Chassis weight
Originally Posted by Chris is me View Post
I think this is a really bad idea. Those hex shafts are designed to be used as spacers, not as drive axles. That part could easily fail when you need it the most.
Spend your weight where it matters. The drivetrain matters.
I think I misspoke, or you misunderstood me. http://www.andymark.com/product-p/am-superoptions.htm
The black plates seen in the image on this page serve as a spacer. We replaced those with this:
http://www.andymark.com/product-p/am-2241.htm
We didn't skimp on anything like a shaft. I misspoke when I called it shaft material. We did use it as a spacer. By using it, we saved a lot of weight.
When I referred to side plates, I didn't mean the main plates, I mean the other four sides, which I replaced with spacers. I apologize for saying it wrong.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 11-01-2013, 14:51
Chris is me's Avatar
AKA: Pinecone
Re: Chassis weight
Oh, I'm sorry, I assumed you were using the cross hex to drive a shaft. Only reason I jumped on it is because I've actually seen teams try to do that on a robot before.
Unread 11-01-2013, 14:55
LightSpeedIII's Avatar
LightSpeedIII LightSpeedIII is offline
Ludicrous Speed!
AKA: Bradley J.
FRC #1086 (Blue Cheese)
LightSpeedIII is an unknown quantity at this point
Re: Chassis weight
Originally Posted by nathan_hui View Post
Did you take into account the 5 lbs or so of bolts, nuts, and washers that usually come together with a chassis? As well as each motor's actual weight?
If I'm not mistaken (and I very well may be), the frame will be welded together, leaving the only bolts, nuts and washers on the frame being used to mount the gearboxes and modules. That weight should include motors, but in the event that it doesn't, adding the weight of 4 CIMs to the 25lb approximation would put it at just a little over 36 pounds.
Looks like they've gone to plaid!
Unread 11-01-2013, 14:57
pmangels17's Avatar
AKA: Paul Mangels
Re: Chassis weight
Oh, no. I just shuddered at the thought. But we will be machining some custom shafts for direct drive, instead of paying for the AM ones. We have two great students (I'd like to think that I'm one of them) that are good at the lathe. I am more the mill guy, and he is more the lathe guy, as we call each other. We also have a tool and dye machinist who works with us as a mentor, and he can practically make anything.
