Go to Post While [a college FIRST competition] would be pretty fun, I think that you'll see this build season that mentoring is a heck of a lot of fun too. (except when the kids pretend to cut their fingers off to see your reaction) - Beth Sweet [more]
Unread 11-01-2013, 17:57
Joseph W. Horth Joseph W. Horth is offline
FRC #0280
Joseph W. Horth is an unknown quantity at this point
FRC Bridge Programming Error
After following all the instructions listed on the FRC Bridge Configuration Utility I keep getting the same following error:
Bridge Programming Failed: Failed to change IP Address
Please ensure the bridge is connected to this computer and try again
I have even tried changing my Local Connection Adapter IP Address to 10.2.80.255 with no luck with that either. What am I doing wrong?
Unread 11-01-2013, 17:58
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Re: FRC Bridge Programming Error
Which radio are you trying to configure (model number/name please)
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 11-01-2013, 18:02
FRC #0280
DAP1522 Rev B
Unread 11-01-2013, 18:08
It's protesting that it cannot change the IP address of the computer you are running the Utility on.
Possibly you have other network connections Enabled?
Go to your Network adaptor settings and make sure all but the one Ethernet port you are using, are Disabled.
By the way, after the utility is done it may leave your computer's Ethernet IP set to 192.168.0.51 and you may need to change it back to DHCP or whatever you normally have it set to.
Unread 11-01-2013, 18:32
FRC #0280
I tried disabling the other network connections but to no avail. Is there any other information I could be leaving out that would help?
Unread 11-01-2013, 18:36
You could try setting the Ethernet IP to 192.168.0.51 yourself. In case the utility checks before bothering to change it.
Unread 11-01-2013, 18:42
FRC #0280
I just tried that and again it didn't work, should I try resetting my computer or reinstalling the Config Utility?
Unread 11-01-2013, 22:43
dellagd's Avatar
AKA: Griffin D
Reset the radio, put the radio in AP mode and see if you can access it on http://192.168.0.50 by connecting a laptop into one of its Ethernet ports
Unread 30-01-2013, 14:07
Barud Barud is offline
FRC #3765
Barud is an unknown quantity at this point
-snip-
